I am confident this post will help some in the future looking to setup LD2410s. I still have some issues that hopefully some of you can help me resolve.
What I’ve learned so far. If working with ESP8266’s (D1 Minis in my case) I found two ways to set them up. With Tasmota and with ESPHome.
If you use Tasmota you have to compile your own bin to include the LD2410. Once you flashed your Tasmota YOU HAVE to use pins TX and RX on the ESP8266 and you can’t invert them. When you go into configure module, for TX you have to select the TX LD2410 from the dropdown, and for RX you select the RX. If you set up TX as RX and RX as TX it won’t work. You then connect the TX pin of the LD2410 device to the RX pin of the ESP8266, and the RX pin to the TX pin.
If you use ESPHome to set up the ESP8266 the connections are backwards. With ESPHome configuration you connect the RX pin of the LD2410 to the RX pin of the ESP8266, and the TX to the TX.
So basically if you flash your ESP8266 and you are able to integrate into home assistant and you are able to see the list of sensors but with no values try inverting the wires that connect the LD2410 to the ESP8266.
this part is actually wrong If you are using an ESP32 with ESPHome things are a bit different. I didn’t try ESP32 with tasmota, only with ESPHome. From documentation it seems you can use any of the pins of the ESP32. I used the TX and RX pins. Also you can switch the pins via code. You can assign TX to be RX, and RX to be TX, or TX to TX and RX to RX. When connecting the LD2410 to the ESP32 you put the TX from the LD2410 to the pin you configured as TX. (Turns out I was wrong in my assumptions, read my reply to my own post)
After figuring that pins swap from tasmota to esphome I was able to set up my ESP32. On that ESP32 I am also running I2S Audio. (Pictures and code I am using will be below).
As you will be able to see on pictures it seems everything is configured properly. I am able to use the Audio part as expected, and I am able to detect motion, presence, distance, etc. But the more advanced features such as turning on engineering mode, turning off bluetooth, restarting device, etc. don’t seem to be working. Could someone help me fix it?
My yaml code:
friendly_name: EspAudiommWave
esp32:
board: esp32dev
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "5EQmST0NJP+H0HJQCMtCWo="
ota:
- platform: esphome
password: "41b15b05"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Espentrada Fallback Hotspot"
password: "maire"
i2s_audio:
i2s_lrclk_pin: GPIO16
i2s_bclk_pin: GPIO17
media_player:
- platform: i2s_audio
name: ESPHome I2S Media Player
dac_type: external
i2s_dout_pin: GPIO21
mode: mono
captive_portal:
uart:
tx_pin: TX
rx_pin: RX
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
uart_id: ld2410_uart
throttle: 1500ms
select:
- platform: ld2410
distance_resolution:
name: distance resolution
baud_rate:
button:
- platform: ld2410
factory_reset:
restart:
query_params:
number:
- platform: ld2410
timeout:
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
switch:
- platform: ld2410
engineering_mode:
bluetooth:
name: "control Bluetooth"
- platform: ld2410
moving_distance:
name: "Moving distance (cm)"
still_distance:
name: "Still Distance (cm)"
moving_energy:
name: "Move Energy (%)"
still_energy:
name: "Still Energy (%)"
detection_distance:
name: "Distance Detection (cm)"
g0:
move_energy:
name: g0 move energy
still_energy:
name: g0 still energy
g1:
move_energy:
name: g1 move energy
still_energy:
name: g1 still energy
g2:
move_energy:
name: g2 move energy
still_energy:
name: g2 still energy
g3:
move_energy:
name: g3 move energy
still_energy:
name: g3 still energy
g4:
move_energy:
name: g4 move energy
still_energy:
name: g4 still energy
g5:
move_energy:
name: g5 move energy
still_energy:
name: g5 still energy
g6:
move_energy:
name: g6 move energy
still_energy:
name: g6 still energy
g7:
move_energy:
name: g7 move energy
still_energy:
name: g7 still energy
g8:
move_energy:
name: g8 move energy
still_energy:
name: g8 still energy
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
Here are the pictures of what my menu looks like
When I toggle the engineering mode the slider goes to the “on” position, then turns off a couple of seconds later. It shows this on the log. I am assuming it is supposed to stay on until I turn it off or reboot the device. Just noticed that if I access the LD2410 via the bluetooth app, if I turn engineering to “on” it updates to “on” in HA, and if I turn it off, it also updates on HA.
When I toggle the control bluetooth the switch does stay in the position I put it on, and on the logbook it shows the command, however it doesn’t matter if it is on or off I am still able to access the LD2410 via the Hilink App. I am assuming the bluetooth control is for the LD2410 not for the ESP32. I haven’t checked if the ESP32 ble is the one turning off and on.
On the timeout. If I set it to 1 then access the LD2410 via the ble app it changes it back to 5. If I change it to 1 via the app it does update to 1 on HA.
Changing distance resolution in HA doesn’t seem to do anything. If I change it via the BLE app it reboots the LD2410 and once it starts up again it does update in the HA
When I click on the restart button, it shows on the log but device doesn’t restart. I know it doesn’t restarts because it keeps showing accurate distances when it should be rebooting.
Any ideas of what might be going on? Seem changes done via the BLE do get pushed to HA, but changes done on HA don’t make it to the LD2410.
