Does anyone experience the issue with LD2410 sensors that the energy of both moving and still are kept at 100% all the time?
I tried to restart the sensor but it didn’t help
Do you have the zones set up correctly for your environment?
The LD2410 doesn’t have zones setup. I’m not sure if I understand you correctly.
Show us your yaml code.
I think I found the root cause, it was due to I mount the sensor on a ceiling with small vibration caused by a ventilation fan. The vibration cause the sensor to output 100% of energy.
