LD2410C - ESP32-C3-DevKitC-02v1.1
LD2410C, all sensors are unavailable. Tried with two ESP32 boards (ESP32_DevKitC_V4 and ESP32-C3-DevkitC-02v1.1), given configuration is for the latter board.
Kindly let me know if anything is missing, I copied the code from ESPHome site. Haven’t connected OUT pin to anything, Vcc to 5V, GND, TX-RX, RX-TX connected.
Based on couple of readings, I tried these to no avail:
  • Changing framework to esp-idf, getting bootloops.
  • Swapping TX-RX port pins in yaml didn’t help.
  • Simplying the configuration to include only binary_sensor
  • Toggling Engineering Mode Switch
esphome:
  friendly_name: esp32-c3-devkitc-02v1.1-ld2410c
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "z7JrvqesDeAZQ6c6+7A2w9TcKC+s9qj/9BWfslqJFnY="
ota:
  password: "01c8b4bf1b29f59dfa18d55baf03bcd8"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-C3-Devkitc-02V11-Ld2410C"
    password: "aYKcdCOF210T"
captive_portal:
uart:
  tx_pin: GPIO21
  rx_pin: GPIO20
  baud_rate: 256000
  data_bits: 8
  stop_bits: 1
  parity: NONE
ld2410:
  uart_id: ld2410_uart
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
switch:
  - platform: ld2410
    engineering_mode:
    bluetooth:
      name: "control bluetooth"
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
number:
  - platform: ld2410
    timeout:
    light_threshold:
      name: light threshold
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
text_sensor:
  - platform: ld2410
    version:
    mac_address:
select:
  - platform: ld2410
    distance_resolution:
      name: "distance resolution"
    baud_rate:
    light_function:
    out_pin_level:
      name: out pin level
Only thing I can suggest is maybe different power? I had to try 3 different ESP32s before I found one that didn’t go into a boot loop with the LD2410 connected to the power pins.
Used GPIO4 for TX and 5 for RX, it started working. Hours spent and lesson learnt time and again is to not use default port of TX/RX.
Enabling engineering mode switch gives g* threshold readings as well. Thanks for the response.
Posting complete yaml in case if it helps someone:
ESP32-C3-DevKitC-02
esphome:
esp32:
  framework:
    type: arduino
# Enable logging
logger:
  baud_rate: 0
api:
  encryption:
ota:
wifi:
  ap:
captive_portal:
uart:
  tx_pin: GPIO4
  rx_pin: GPIO5
  baud_rate: 256000
  data_bits: 8
  stop_bits: 1
  parity: NONE
ld2410:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
switch:
  - platform: ld2410
    engineering_mode:
    bluetooth:
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
      still_energy:
    g1:
      move_energy:
      still_energy:
    g2:
      move_energy:
      still_energy:
    g3:
      move_energy:
      still_energy:
    g4:
      move_energy:
      still_energy:
    g5:
      move_energy:
      still_energy:
    g6:
      move_energy:
      still_energy:
    g7:
      move_energy:
      still_energy:
    g8:
      move_energy:
      still_energy:
number:
  - platform: ld2410
    timeout:
    light_threshold:
    g0:
      move_threshold:
      still_threshold:
    g1:
      move_threshold:
      still_threshold:
    g2:
      move_threshold:
      still_threshold:
    g3:
      move_threshold:
      still_threshold:
    g4:
      move_threshold:
      still_threshold:
    g5:
      move_threshold:
      still_threshold:
    g6:
      move_threshold:
      still_threshold:
    g7:
      move_threshold:
      still_threshold:
    g8:
      move_threshold:
      still_threshold:
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
text_sensor:
  - platform: ld2410
    version:
    mac_address:
select:
  - platform: ld2410
    baud_rate:
    light_function:
    out_pin_level:
      name: out pin level
Thank you Varun. I had the same problem, and your post solved my problem. :pray:
