LD2410C vs LD1125H, the latter responds faster
Hello all,
I tried LD1125H and then followed by 2410C, after installing the latter, I could clearly see a delay in triggering light automation. So, I tried both the sensors in the ceiling in different setups (three placement swaps); and swapped esp32 boards as well and LD1125H triggered faster every time.
For LD2410C, the Presence sensor seems finicky, hence I relied only on Moving Target sensor.
Here are the logs from Home Assistant, and LD1125H is hundreds of milliseconds faster than LD2410C in every test. The first two corresponds to LD1125H (coming early in the logs), and the 3rd/4th lines are of LD2410C
Setup-1
2024-01-24 06:43:46.862 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 06:43:46.862 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 06:43:47.620 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 06:43:47.620 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
2024-01-24 06:45:09.369 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 06:45:09.369 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 06:45:10.322 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 06:45:10.322 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
2024-01-24 06:46:21.266 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 06:46:21.266 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 06:46:22.014 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 06:46:22.014 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
Setup-2
2024-01-24 12:24:42.744 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 12:24:42.744 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 12:24:43.038 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 12:24:43.038 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
2024-01-24 12:25:43.697 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 12:25:43.697 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 12:25:45.542 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 12:25:45.543 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
2024-01-24 12:26:37.359 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 12:26:37.359 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 12:26:38.931 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 12:26:38.931 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
Setup-3
2024-01-24 13:14:33.078 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 13:14:33.079 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 13:14:33.854 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 13:14:33.854 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
2024-01-24 13:15:40.703 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 13:15:40.703 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 13:15:41.148 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 13:15:41.148 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
2024-01-24 13:16:11.753 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Running automation actions
2024-01-24 13:16:11.753 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_on] Guest Bathroom On - 1125H: Executing step call service
2024-01-24 13:16:12.052 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Running automation actions
2024-01-24 13:16:12.052 INFO (MainThread) [homeassistant.components.automation.guest_bathroom_cc_2410c] Guest Bathroom On - 2410C: Executing step call service
LD1125H Configuration
LD2410C Configuration
Photos
