rgnyldz
(ErgĂĽn YILDIZ)
June 21, 2025, 5:22pm
1
I have a strange issue on a few of my esp devices where after I update the code and upload it over OTA the LD2420 sensor fails.
The sensor starts working after I unplug the USB and plug it back again (energy cut).
This happens on various devices (esp32-c6, S3, regular esp32)
substitutions:
friendly_name: Office Stairs Sensor
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
project:
version: '1.0'
on_boot:
priority: 250
then:
- wait_until:
condition:
wifi.connected:
timeout: 5s
esp32:
board: esp32-c6-devkitc-1
variant: esp32c6
framework:
type: esp-idf
logger:
level: VERBOSE
api:
encryption:
key: "XXX"
ota:
- platform: esphome
password: "XXX"
wifi:
networks:
- ssid: !secret wifi_ssid
- ssid: !secret wifi_ssid2
password: !secret wifi_password2
captive_portal:
improv_serial:
uart:
tx_pin: GPIO6
rx_pin: GPIO5
baud_rate: 115200
parity: NONE
stop_bits: 1
ld2420:
number:
- platform: ld2420
presence_timeout:
name: Detection Presence Timeout
min_gate_distance:
name: Detection Gate Minimum
max_gate_distance:
name: Detection Gate Maximum
gate_select:
name: Select Gate to Set
still_threshold:
name: Set Still Threshold Value
move_threshold:
name: Set Move Threshold Value
# - platform: wifi_signal
# name: "WiFi Signal"
# update_interval: 3s
- platform: ld2420
moving_distance:
binary_sensor:
- platform: ld2420
has_target:
text_sensor:
- platform: ld2420
fw_version:
select:
- platform: ld2420
operating_mode:
button:
- platform: ld2420
apply_config:
factory_reset:
restart_module:
revert_config:
light:
- platform: esp32_rmt_led_strip
name: "On board LED"
num_leds: 1
pin: GPIO8
rgb_order: GRB
chipset: ws2812
rmt_symbols: 48
rgb_order: GRB
is_rgbw: true
chipset: SK6812
pin: GPIO7
num_leds: 24
rmt_symbols: 48
Teknor
July 18, 2025, 10:13pm
2
I have the same error. Still have not figured out how to make it work again.
[00:09:29][W][ld2420:211]: Firmware version v0.0.0 and older supports Simple Mode only
[00:09:29][E][component:141]: ld2420 is marked FAILED: unspecified
Teknor
July 23, 2025, 8:24am
3
Solved: Changed the framework type from arduino to esp-idf. Now ut works like it used to.
rgnyldz
(ErgĂĽn YILDIZ)
July 25, 2025, 5:28pm
4
I’m not sure that it’s related to framework because I’m already on esp-idf and still get the same error.
Happy that you have solved yours tho
I’m also seeing the same behaviour.
Using a xiao-esp32c3. I have framework type set to esp-idf. I don;t experience this with the LD2010C.
I’ll try to use another ld2420 to see if its the sensor that’s defective.
# Wiring
# esp32-c3 -> ld2420
# 3.3v -> 3.3v
# GND -> GND
# D10 (tx) -> rx
# D1(rx) - > OT1 (tx)
# D2 - > OT2
# You can use other GPIO pins for UART then D7 and D6 which interfere with the USB UART
esphome:
friendly_name: presence-sensor-basement
min_version: 2025.5.0
esp32:
board: seeed_xiao_esp32c3
variant: esp32c3
framework:
type: esp-idf
# Enable logging
logger:
baud_rate: 0
wifi:
domain: .local
fast_connect: true
ota:
platform: esphome
password: !secret ota_password
api:
encryption:
key: !secret api_encryption_key
reboot_timeout: 60s
esp32_ble_tracker:
max_connections: 3
bluetooth_proxy:
active: true
connection_slots: 3
uart:
tx_pin: GPIO10
rx_pin: GPIO3
baud_rate: 115200
parity: NONE
stop_bits: 1
Hi!
I used the same sensor with an esp32-c6 and no longer saw the problem.
I tried another ld2420 on the esp32-c3 ( the one with the original issue ) and still experienced the same problem.
I’ll run the esp32-c6 for a bit and see how it behaves.
I Got it working LD2420 - ESP32C3 SuperMini ( Ali Express)
I had the same issue and spent nearly a week trying to get it working. I’m using the ESP32-C3 Super Mini (HW-466AB) , which I purchased from AliExpress.
For some reason, the board was still holding on to the previous firmware or sketch, even when flashing it using esptool.py.
Here’s what finally worked for me:
Hold down the BOOT button
While still holding BOOT, press and release the RESET button
Release the BOOT button
Once that was done, I uploaded the config via USB and did a power cycle.(Unplug and replug)
To my great surprise it showed the firmware version
23:01:58][C][ld2420:187]: LD2420:
[23:01:58][C][ld2420:187]: Firmware version: v1.6.1
I have also been using external usb power for stable power.
esphome:
friendly_name: Presence Sensor - LD2420 - ESPC3
platformio_options:
upload_speed: 921600
board_build.flash_mode: dio
esp32:
board: esp32-c3-devkitc-02
variant: ESP32C3
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
ota:
- platform: esphome
wifi:
manual_ip:
static_ip: 192.168.50.15
gateway: 192.168.50.1
subnet: 255.255.255.0
dns1: 192.168.50.1
reboot_timeout: 20min
fast_connect: True
power_save_mode: NONE
uart:
tx_pin: GPIO21
rx_pin: GPIO20
baud_rate: 115200
parity: NONE
stop_bits: 1
ld2420:
text_sensor:
- platform: ld2420
fw_version:
- platform: ld2420
moving_distance:
binary_sensor:
- platform: ld2420
has_target:
select:
- platform: ld2420
operating_mode:
number:
- platform: ld2420
presence_timeout:
min_gate_distance:
max_gate_distance:
# See "Number" section below for detail
gate_select:
still_threshold:
move_threshold:
button:
- platform: ld2420
apply_config:
factory_reset:
restart_module:
revert_config:
rgnyldz
(ErgĂĽn YILDIZ)
August 2, 2025, 8:23am
8
Hey @svdennis good to hear and thanks for the explanation and the time you put in.
Does the LD2420 still work after you upload anything over OTA? Or do you also have to unplug/plug power in order for it to work?
Hey @rgnyldz
It fails!
Yeah thats thing, unless I do a hard reset and not to ota it works.
The minute I update via OTA . It fails!!!
I was happy that I got it work!
I got excited a little too early!
Still looking to find a solution.
agusluques
(Agus Luques)
August 7, 2025, 10:48pm
10
Same issue here. The OTA works and the ESP32-c3 gets updated, but as soon as it tries to boot it fails. On a physically restart, it workds with the updated version of the configuration.
It only happens via “Wirelessly”. USB plug works fine.
zodyking
(The Engineer)
August 8, 2025, 12:31am
11
rgnyldz:
substitutions:
esphome:
project:
version: '1.0'
on_boot:
priority: 250
then:
- wait_until:
condition:
wifi.connected:
timeout: 5s
esp32:
variant: esp32c6
framework:
type: esp-idf
logger:
level: VERBOSE
api:
encryption:
key: "XXX"
ota:
- platform: esphome
password: "XXX"
wifi:
networks:
captive_portal:
improv_serial:
uart:
tx_pin: GPIO6
rx_pin: GPIO5
baud_rate: 115200
parity: NONE
stop_bits: 1
ld2420:
number:
- platform: ld2420
presence_timeout:
min_gate_distance:
max_gate_distance:
gate_select:
still_threshold:
move_threshold:
- platform: ld2420
moving_distance:
binary_sensor:
- platform: ld2420
has_target:
text_sensor:
- platform: ld2420
fw_version:
select:
- platform: ld2420
operating_mode:
button:
- platform: ld2420
apply_config:
factory_reset:
restart_module:
revert_config:
light:
num_leds: 1
pin: GPIO8
rgb_order: GRB
chipset: ws2812
rmt_symbols: 48
rgb_order: GRB
is_rgbw: true
chipset: SK6812
pin: GPIO7
num_leds: 24
rmt_symbols: 48
I use Arduino frame work and it works just fine for me, ESP32 Dev Kit C
esphome:
friendly_name: Bathroom Sensor
esp32:
board: esp32dev
framework:
type: arduino
logger:
api:
encryption:
key: ""
ota:
- platform: esphome
password: "ddd1e0ac8c1b4f495f0c0ed23e3f31db"
wifi:
ssid: ""
password: ""
ap:
ssid: "Bathroom-Sensor Fallback Hotspot"
password: "lm9DMvI8oRIr"
captive_portal:
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 256000
parity: NONE
stop_bits: 1
debug:
direction: BOTH
dummy_receiver: false
after:
delimiter: [0xF8]
ld2410:
uart_id: ld2410_uart
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
out_pin_presence_status:
name: Out Pin Presence Status
- platform: ld2410
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0:
move_energy:
name: g0 Move Energy
still_energy:
name: g0 Still Energy
g1:
move_energy:
name: g1 Move Energy
still_energy:
name: g1 Still Energy
g2:
move_energy:
name: g2 Move Energy
still_energy:
name: g2 Still Energy
g3:
move_energy:
name: g3 Move Energy
still_energy:
name: g3 Still Energy
g4:
move_energy:
name: g4 Move Energy
still_energy:
name: g4 Still Energy
g5:
move_energy:
name: g5 Move Energy
still_energy:
name: g5 Still Energy
g6:
move_energy:
name: g6 Move Energy
still_energy:
name: g6 Still Energy
g7:
move_energy:
name: g7 Move Energy
still_energy:
name: g7 Still Energy
g8:
move_energy:
name: g8 Move Energy
still_energy:
name: g8 Still Energy
number:
- platform: ld2410
timeout:
light_threshold:
name: Light Threshold
max_move_distance_gate:
name: Max Move Distance Gate
max_still_distance_gate:
name: Max Still Distance Gate
g0:
move_threshold:
name: g0 Move Threshold
still_threshold:
name: g0 Still Threshold
g1:
move_threshold:
name: g1 Move Threshold
still_threshold:
name: g1 Still Threshold
g2:
move_threshold:
name: g2 Move Threshold
still_threshold:
name: g2 Still Threshold
g3:
move_threshold:
name: g3 Move Threshold
still_threshold:
name: g3 Still Threshold
g4:
move_threshold:
name: g4 Move Threshold
still_threshold:
name: g4 Still Threshold
g5:
move_threshold:
name: g5 Move Threshold
still_threshold:
name: g5 Still Threshold
g6:
move_threshold:
name: g6 Move Threshold
still_threshold:
name: g6 Still Threshold
g7:
move_threshold:
name: g7 Move Threshold
still_threshold:
name: g7 Still Threshold
g8:
move_threshold:
name: g8 Move Threshold
still_threshold:
name: g8 Still Threshold
The work around I currently use is and it seems to be working,
Once I do the OTA, I unplug the ESP32, hold the RST button and plug the cable in, this seems to send the data correctly to home assistant.
Since I have the 3D case printed, I had no way to have the RST button out all the time.
I used a toothpick as a temporary work around
g0rski
(G0rski)
August 28, 2025, 4:46pm
13
Thanks man! that saved me many hours of debugging!
rgnyldz
(ErgĂĽn YILDIZ)
February 26, 2026, 8:59am
14
I see there are some updates for the LD2420 component inside esphome builder.
Has anyone got luck with this issue with the latest updates?
I tried with the new esphome builder versions and it still fails after OTA. Works only after hard power reset.
