Hi to all! Need help here.
Problem: Cannot install ESPHome on AtomLite (ESP32) board with LD2420
Set-UP:
ESP-Home 2023.10.6
HA 2023.10.3
ESP32 = Atom Lite link
Sensor = LD2420 link
Description:
When installing this yaml file (code below), file preparation shows the error:
Question:
Am I using the wrong external component link?
What am I doing wrong?
INFO ESPHome 2023.10.6
INFO Reading configuration /config/esphome/presence01.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/4847/head
Failed config
ESPHome yaml file is:
external_components:
- source: github://pr#4847
components: [ ld2420 ]
refresh: 0s
esphome:
friendly_name: "mmwave01"
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "cTy9RiVi61wyb1dnvAQqiPMNTyl5jviJO4lQ/aC7jXc="
ota:
password: "20755a16743d40176874c4f8625013a0"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Teste Fallback Hotspot"
password: "mtem1GYyg9YP"
captive_portal:
esp32_ble_tracker:
uart:
tx_pin: 22
rx_pin: 19
baud_rate: 115200
parity: NONE
stop_bits: 1
ld2420:
presence_time_window: 30s
detection_gate_min: 1
detection_gate_max: 12
g0_move_threshold: 60000
g0_still_threshold: 40000
g1_move_threshold: 30000
g1_still_threshold: 20000
g2_move_threshold: 400
g2_still_threshold: 200
g3_move_threshold: 250
g3_still_threshold: 200
g4_move_threshold: 250
g4_still_threshold: 200
g5_move_threshold: 250
g5_still_threshold: 200
g6_move_threshold: 250
g6_still_threshold: 200
g7_move_threshold: 250
g7_still_threshold: 150
g8_move_threshold: 250
g8_still_threshold: 150
g9_move_threshold: 250
g9_still_threshold: 100
g10_move_threshold: 250
g10_still_threshold: 100
g11_move_threshold: 250
g11_still_threshold: 100
g12_move_threshold: 250
g12_still_threshold: 100
g13_move_threshold: 200
g13_still_threshold: 100
g14_move_threshold: 200
g14_still_threshold: 100
g15_move_threshold: 200
g15_still_threshold: 100
- platform: ld2420
moving_distance:
name : Distancia do Movimento
binary_sensor:
- platform: ld2420
has_target:
- platform: gpio
pin:
number: 26
mode: INPUT_PULLUP
device_class: light
#on_press:
# - homeassistant.service:
# service: light.turn_off
# data:
# entity_id: light.escritorio_mesa
#on_release:
# service: light.turn_on
# data:
- platform: gpio
pin:
number: 39
inverted: false
on_press:
then:
- light.toggle: status_led
light:
- platform: fastled_clockless
chipset: WS2812B
pin: 27
num_leds: 1
rgb_order: GRB
effects:
- random:
- flicker:
- addressable_rainbow:
switch:
- platform: restart
The entire log file reads:
Failed config
ld2420: [source /config/esphome/presence01.yaml:45]
[presence_time_window] is an invalid option for [0]. Please check the indentation.
[detection_gate_min] is an invalid option for [0]. Please check the indentation.
[detection_gate_max] is an invalid option for [0]. Please check the indentation.
[g0_move_threshold] is an invalid option for [0]. Please check the indentation.
[g0_still_threshold] is an invalid option for [0]. Please check the indentation.
[g1_move_threshold] is an invalid option for [0]. Please check the indentation.
[g1_still_threshold] is an invalid option for [0]. Please check the indentation.
[g2_move_threshold] is an invalid option for [0]. Please check the indentation.
[g2_still_threshold] is an invalid option for [0]. Please check the indentation.
[g3_move_threshold] is an invalid option for [0]. Please check the indentation.
[g3_still_threshold] is an invalid option for [0]. Please check the indentation.
[g4_move_threshold] is an invalid option for [0]. Please check the indentation.
[g4_still_threshold] is an invalid option for [0]. Please check the indentation.
[g5_move_threshold] is an invalid option for [0]. Please check the indentation.
[g5_still_threshold] is an invalid option for [0]. Please check the indentation.
[g6_move_threshold] is an invalid option for [0]. Please check the indentation.
[g6_still_threshold] is an invalid option for [0]. Please check the indentation.
[g7_move_threshold] is an invalid option for [0]. Please check the indentation.
[g7_still_threshold] is an invalid option for [0]. Please check the indentation.
[g8_move_threshold] is an invalid option for [0]. Please check the indentation.
[g8_still_threshold] is an invalid option for [0]. Please check the indentation.
[g9_move_threshold] is an invalid option for [0]. Please check the indentation.
[g9_still_threshold] is an invalid option for [0]. Please check the indentation.
[g10_move_threshold] is an invalid option for [0]. Please check the indentation.
[g10_still_threshold] is an invalid option for [0]. Please check the indentation.
[g11_move_threshold] is an invalid option for [0]. Please check the indentation.
[g11_still_threshold] is an invalid option for [0]. Please check the indentation.
[g12_move_threshold] is an invalid option for [0]. Please check the indentation.
[g12_still_threshold] is an invalid option for [0]. Please check the indentation.
[g13_move_threshold] is an invalid option for [0]. Please check the indentation.
[g13_still_threshold] is an invalid option for [0]. Please check the indentation.
[g14_move_threshold] is an invalid option for [0]. Please check the indentation.
[g14_still_threshold] is an invalid option for [0]. Please check the indentation.
[g15_move_threshold] is an invalid option for [0]. Please check the indentation.
[g15_still_threshold] is an invalid option for [0]. Please check the indentation.
