I uploaded this code
substitutions:
friendly_name: radar
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
project:
version: '1.0'
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
# To have a "next url" for improv serial
web_server:
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 115200
parity: NONE
stop_bits: 1
ld2420:
setup_priority: -100
text_sensor:
- platform: ld2420
fw_version:
- platform: ld2420
moving_distance:
binary_sensor:
- platform: ld2420
has_target:
switch:
- platform: restart
name: Restart ESPHome Node
select:
- platform: ld2420
operating_mode:
number:
- platform: ld2420
presence_timeout:
name: Detection Presence Timeout
min_gate_distance:
name: Detection Gate Minimum
max_gate_distance:
name: Detection Gate Maximum
gate_select:
name: Select Gate to Set
still_threshold:
name: Set Still Threshold Value
move_threshold:
name: Set Move Threshold Value
button:
- platform: ld2420
apply_config:
factory_reset:
restart_module:
revert_config:
but when logging the output, i get an watchdog error on LD2420 setup.
What could cause this problem, tryed swapping RX and TX but that doesn’t help.
