LD2420 with esphome GPIO output enable
I have an ld2420 (Firmware ver 1.5.9) wired to a d1_mini and have put the GPIO out pin to D0.
I am aiming to take the output from the GPIO pin (HIGH for Presence, LOW for ABSENCE) and publish it to my broker using MQTT. I believe that the GPIO pin needs to be enabled and here I am stuck.
Below is the relevant sections of the LD2420 code that compiles but the GPIO pin doesn’t change from LOW to HIGH when presence is detected.
If I look at the log and physically bring the pin from LOW to HIGH I can see that change being reported in the log but it immediately reverts to LOW when not physically pulled HIGH.
Any Ideas?
uart:
  tx_pin: D5
  rx_pin: D6
  baud_rate: 115200
  parity: NONE
  stop_bits: 1
# Scripts to Send Hex Strings
script:
  - id: send_hex_string_1
    then:
      - uart.write: [0xFF, 0x55, 0x07, 0x01, 0x05, 0x00, 0x01, 0x00, 0x64] #initialize gpio D0
  - id: send_hex_string_2
    then:
      - uart.write: [0xFF, 0x55, 0x08, 0x01, 0x03, 0x00, 0x1F, 0x40, 0xB8] #set 8 m detection distance
# The LD2420 has 16 sense gates 0-15 and each gate detects 0.7 meters 15th gate = 9m
ld2420:
text_sensor:
  - platform: ld2420
    fw_version:
binary_sensor:
  - platform: gpio
    pin:
      number: D0
      mode: INPUT_PULLDOWN
    on_press:
      then:
        - logger.log: "D0 State is ON"
        - mqtt.publish:
            topic: "${mqtt_prefix}/KITCHEN/HMMD_4/SWITCH/MAIN/SENSOR"
            payload: "ON"
    on_release:
      then:
        - logger.log: "D0 State is OFF"
        - mqtt.publish:
            payload: "OFF"
select:
  - platform: ld2420
    operating_mode:
number:
  - platform: ld2420
    presence_timeout:
      name: Detection Presence Timeout # How long before the sensor is set to cleared after last detection
    min_gate_distance:
      name: Detection Gate Minimum
    max_gate_distance:
      name: Detection Gate Maximum
    gate_select:
      name: Select Gate to Set
    still_threshold:
      name: Set Still Threshold value
    move_threshold:
      name: Set Move Threshold value
button:
  - platform: ld2420
    apply_config:
      name: Apply Config # applies configuration (used to set calibrated values)
    factory_reset:
      name: Factory Reset # As the name says
    restart_module:
      name: Restart Module # as the name says
    revert_config:
# Publish D7 State to MQTT Every 10 Seconds
interval:
  - interval: 10s
    then:
      - mqtt.publish:
          payload: !lambda 'return id(d0_state).state ? "ON" : "OFF";'ype or paste code here
