Anyone have any idea how to get these two sensors close without interfering with each other? I seem to put them side by side and the 2412 gets much higher detection levels leading to false positives.
You might want to take a look at the R-PRO-1 device from Apollo Automation. Check out pictures on the product web site, as to how they situate those two particular mmWave sensors.
The 2412 is directly below the 2450 on theirs. I tried that positioning and had issues. Dunno if it’s just the nature of the mmWave and theirs also has problems or if there’s some setting that I’m missing.
Did you run the background correction?
Yep. Background corrections just set the amount needed to trigger. If an empty room is giving off 100% spikes only when the 2450 is on I don’t think that helps.
But I also had one randomly start working properly so maybe I didn’t have a dupont cable properly seated on a pin or something. I’m still having the same issue with a second assembly so it’s not like I’m imagining things. ![]()
