Hey,
I’ve got my LD2450 set and working with a d1 mini,
I am facing a few issues:
1. The zone doesn’t work as intended, Yes the zone creates perfectly but the zone status stays active and doesn’t change to inactive when no presence is detected in the specified zone.
2. After every restart either from esp8266 or HASS the zones reset to defaults and the multi-tracking toggle goes off.
3. Zones in Automation cannot be used as a trigger as they are always set to active.
Any help will be really appreciated, a newbie to HASS.
Here is my yaml for esp8266:
esphome:
friendly_name: Bedroom Presence
esp8266:
board: d1_mini
external_components:
- source: github://pr#5674
components: [ ld2450 ]
refresh: 0s
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "***********************************"
ota:
- platform: esphome
password: "*********************************"
wifi:
ssid: ******** wifi_ssid
password: ******** wifi_password
ap:
ssid: "Bedroom-Presence"
password: "*********"
captive_portal:
uart:
tx_pin: GPIO1 # TX Pin (ESP8266 D1 Mini)
rx_pin: GPIO3 # RX Pin (ESP8266 D1 Mini)
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2450:
uart_id: ld2450_uart
throttle: 1000ms
binary_sensor:
- platform: ld2450
ld2450_id: ld2450_sensor
has_target:
has_moving_target:
has_still_target:
name: "Zone 1 Active"
lambda: |-
return (id(zone_1_x1).state != 0 || id(zone_1_y1).state != 0 ||
id(zone_1_x2).state != 0 || id(zone_1_y2).state != 0);
name: "Zone 2 Active"
lambda: |-
return (id(zone_2_x1).state != 0 || id(zone_2_y1).state != 0 ||
id(zone_2_x2).state != 0 || id(zone_2_y2).state != 0);
name: "Zone 3 Active"
lambda: |-
return (id(zone_3_x1).state != 0 || id(zone_3_y1).state != 0 ||
id(zone_3_x2).state != 0 || id(zone_3_y2).state != 0);
- platform: ld2450
target_count:
name: "Presence Target Count"
still_target_count:
name: "Still Target Count"
moving_target_count:
name: "Moving Target Count"
target_1:
x:
y:
speed:
angle:
distance:
name: "Target-1 Distance"
resolution:
name: "Target-1 Resolution"
target_2:
x:
y:
speed:
angle:
distance:
name: "Target-2 Distance"
resolution:
name: "Target-2 Resolution"
target_3:
x:
y:
speed:
angle:
distance:
name: "Target-3 Distance"
resolution:
name: "Target-3 Resolution"
number:
- platform: ld2450
presence_timeout:
zone_1:
x1:
y1:
x2:
y2:
zone_2:
x1:
y1:
x2:
y2:
zone_3:
x1:
y1:
x2:
y2:
switch:
- platform: ld2450
bluetooth:
multi_target:
name: "Multi Target Tracking"
select:
- platform: ld2450
baud_rate:
zone_type:
text_sensor:
- platform: ld2450
version:
name: "LD2450 Firmware"
mac_address:
name: "LD2450 BT MAC Address"
target_1:
direction:
name: "Target-1 Direction"
target_2:
direction:
name: "Target-2 Direction"
target_3:
direction:
name: "Target-3 Direction"
