Hi all,
I am working on battery powered ESP devices that need 3.3V. I’m experimenting with 2 x AA and single Li-Ion cells:
I’m currently using an MCP1700 LDO but understand any LDO will dissipate “excess voltage” as heat so not the most efficient.
I have seen folks using step-down regulators like the LM3671 but am a bit confused as it looks like it can work with an input voltage range -0.2V to 6V, which means it’s step up for < 3.3V and step down for > 3.3V.
Likewise I’ve seen the LM3525 step-up used but that seems to have a –0.3V to 6V range, meaning it’s both step up and step down.
If I want to provide an efficient 3.3V with batteries that will supply both below and above 3.3V as they discharge, do I need to use a step-up and step-down regulator or just stick a step-down or step-up regulator and not worry about it?
I guess I’m hung up on the “step-down” nomenclature as that suggests when a battery drops below 3.3V it won’t be very effective. Same for “step-up” and for an LDO - if the battery voltage is below 3.3v - the dropout voltage I would assume the regulator wouldn’t work very well?
