This blueprint automatically detects all moisture sensors in your Home Assistant system — no need to manually select sensors. It sends customizable mobile notifications with your own title and message.
Optional features include:
Supports multiple mobile devices
Auto-clear notifications when the sensor goes dry
Repeating alarms until the leak is cleared
Optional script execution when a leak is detected
Most likely there are similar blueprints, but everything I found didn’t include the option to automatically trigger on all moisture sensors without adding them manually.
Forked from: bbbenji/leak-detector-notifier.yaml
The original didn’t have enough functionality for my needs: custom warning text, leak clear message, repeating alarm, and optional script execution.
P.S.: This blueprint was updated and enhanced with help from ChatGPT.
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that. Create a link – My Home Assistant
You need to be a trust level ‘member’ to edit a post. Understanding Discourse Trust Levels
If you can’t edit, I would load a link into a second post.
Please update blueprint in your system. I have added option for adding multiply devices. SO far tested on iOS devices and it work fine. Let me know if something is wrong.
I’ve updated my Home Assistant leak detection blueprint with several improvements to make it more reliable and smarter:
New improvements:
• Detects only real state transitions (off → on and on → off)
• Prevents false “leak cleared” alerts after Home Assistant restart (unavailable → off)
• Notifications now include the room/area name
These changes make the automation more robust, restart-safe, and easier to maintain in setups with many leak sensors.
One suggestion I would like to give is to use (out give the possibility to use) “persistent notification” in HA, I think they are better for this type of urgent notifications and you cannot miss them
@Gromozeka
as most of my notifications are on silent
Is it possible to add the code
for the notify action
channel: alarm
as i have a common alarm that make a noise and overrides dnd and a critical alert i must know about
have been playing all morning but i cant get to work
P.S Great blueprint
