I’ve setup my RM4 Pro with HA and managed to learn a couple of codes, however when I run call service with the code below, the light turns on and off again. The same happens with the brightness command, when I run it the brightness jumps 2 steps not 1. Am I doing something wrong or is there a problem learning the codes?
entity_id: remote.rm4_pro_remote
device: Lamp1
command: Power On’
