OK, so… I am just starting out with HA. I did program things years and years (and years) ago, have learned custom integrations in the past (RTI, AMX, Creston), and also well-versed in the industrial side (Rockwell/Ladder Logic stuff). However, I’m scratching my head with yaml. I have successfully added all my devices in (localtuya), done a crapload of simple automations (tied to single or multi-location switches), and done a few more “complex” automations that involve calling scripts. But, I’m having issues with a simple one to brighten up the front door during a doorbell press.
Here is what I have. The last bit is breaking it. It’s looking for expected dictionary @ data[‘action’][1]. Got none
But, I have used this in the past in other spots and it seems to work out fine. Why is it broken here? I thought I had the whole list vs dictionary thing down pat, but…
Any clue on how to fix?
- id: 'FrontDoorRing'
alias: Front Door Ring
- platform: state
entity_id: binary_sensor.front_door_ding
to: 'on'
- service: scene.create
scene_id: pre_fd_ring
snapshot_entities:
- light.front_door_l
- light.front_door_r
- delay 00:00:01
- service: light.turn_on
entity_id: light.front_door_l
brightness_pct: 100
# - service: light.turn_on
# entity_id: light.front_door_r
# data:
# brightness_pct: 100
# transition: 0
# mode: single
Don’t beat yourself up, it’s just a typo. You forgot the colon after the word delay
- delay 00:00:01
Wrapping the time in quotes is optional.
BTW, this @ data[‘action’][1] means the second item in the action (it indicates 1 but it’s indexed from zero). The second item in the action is the delay.
The second service call is incorrectly ordered. When a service call requires / has a ‘data’ section in it then the entity_id needs to be under the ‘data’ heading with the rest of the service call data. (I think… maybe it works both ways)
- platform: state
to: 'on'
snapshot_entities:
- delay: '00:00:01'
brightness_pct: 100
# data:
# transition: 0
# mode: single
Much thanks. I thought I had the basics down, figured it was a simple thing staring me at the face.
Also, thanks for the explanation of the data[‘action’][1]. That is probably more help than the actual fixing of this issue. (Teach a man to fish, yadda yadda). I just wish it would direct you to the automation that was causing the error as well…
I think it does because I vaguely recall having it outside data when I used brightness and it worked. I say ‘vaguely’ because I normally move it into data for neatness.
