I have been playing with Home Assistant for 2 weeks now and have hit my first config file issue that I cannot figure out. This is just a test system for me to play with before I do anything for the house.
I have 2 multisensors that use nodemcu’s.
I have home assisntant with mqtt enabled.
When I power up the multisensor I can see data being passed to home assistant ui (all good so far)
When I then edit the config file to add the second sensor, the first stops working and the data from the first multisensor appears in the second sensor from the config file. I cannot see why the first sensor entry would be removed when adding the second one. Am I missing something obvious?
Here is the sensor code for the config
mqtt:
broker: 192.168.0.68
port: 1883
client_id: home-assistant-1
username: mqtt
password:xxxxx
#Sensor 1
- platform: mqtt
state_topic: "bruh/sensornode1"
name: "SN1 Humidity"
unit_of_measurement: "%"
value_template: '{{ value_json.humidity | round(1) }}'
- platform: mqtt
unit_of_measurement: "LUX"
value_template: '{{ value_json.ldr }}'
- platform: mqtt
value_template: '{{ value_json.motion }}'
- platform: mqtt
name: "SN1 Temperature"
unit_of_measurement: "°F"
value_template: '{{ value_json.temperature | round(1) }}'
- platform: mqtt
name: "SN1 Real Feel"
value_template: '{{ value_json.heatIndex | round(1) }}'
group:
sensor_node_1_card:
name: Sensor Node 1
entities:
- sensor.sn1_temperature
- sensor.sn1_humidity
- sensor.sn1_ldr
- sensor.sn1_pir
- light.sn1_led
#Sensor2
- platform: mqtt
state_topic: "bruh/sensornode2"
name: "SN2 Humidity"
- platform: mqtt
- platform: mqtt
- platform: mqtt
name: "SN2 Temperature"
- platform: mqtt
name: "SN2 Real Feel"
group:
sensor_node_2_card:
name: Sensor Node 2
entities:
- sensor.sn2_temperature
- sensor.sn2_humidity
- sensor.sn2_ldr
- sensor.sn2_pir
- light.sn2_led
