Learning NodeRed, my first flow to determine house "status" based on time and presence
Hello everyone, I have been learning NodeRed these past few weeks and my first project is to determine my house “status” depending on the time of the day AND whether or not we are home. I am defining 4 different “status” modes : Day, Evening, Bedtime and Away. I figure that a lot of my home automations can stem from those 4 statuses. For example whether lights are on or off, alarms and cameras on or off, etc…so I want to get this right.
So I started with 4 Input booleans for the Status, plus an additional one depending if the house is empty or one of us is at home. I use Life360 as the tracker to determine this portion.
I want to be able to toggle these Status(es) based on time of the day AND based on presence. Plus I want to be able to toggle them manually as well (for example toggle Bedtime when we actually go to bed as opposed to a set time of the evening -11PM in my automation-).
My flow is pasted below. I am a beginner and therefore hope that I can get some constructive ideas on how to make it better (it is working though) and perhaps it can also help a fellow beginner that would want to get started on the same.
Thanks !
[{"id":"5f937561.f25ebc","type":"tab","label":"Home status","disabled":false,"info":""},{"id":"bdae643f.ae50c8","type":"api-call-service","z":"5f937561.f25ebc","name":"Set status to Away","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.house_away","data":"{   \"entity_id\": \"input_boolean.house_away\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":870,"y":660,"wires":[["45bb5a5f.c39834","9824dc47.49b27"]]},{"id":"45bb5a5f.c39834","type":"api-call-service","z":"5f937561.f25ebc","name":"Day to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_day","data":"{   \"entity_id\": \"input_boolean.house_day\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1140,"y":680,"wires":[[]]},{"id":"9824dc47.49b27","type":"api-call-service","z":"5f937561.f25ebc","name":"Bedtime to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_night","data":"{   \"entity_id\": \"input_boolean.house_night\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1160,"y":800,"wires":[[]]},{"id":"7a5e1418.069b0c","type":"comment","z":"5f937561.f25ebc","name":"Set Home Status","info":"","x":80,"y":40,"wires":[]},{"id":"62c713fb.3a652c","type":"bigtimer","z":"5f937561.f25ebc","outtopic":"","outpayload1":"ON","outpayload2":"OFF","name":"5:30AM-Sunset Timer","comment":"","lat":"37.1135","lon":"-121.992","starttime":"330","endtime":"5004","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"ON","outtext2":"OFF","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":140,"y":140,"wires":[["419699db.c08128"],[],[]]},{"id":"419699db.c08128","type":"switch","z":"5f937561.f25ebc","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":140,"wires":[["72e90d12.816444"],["6b137983.945628"]]},{"id":"b6beb32c.2792b","type":"api-call-service","z":"5f937561.f25ebc","name":"Normal Day to On","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.house_day","data":"{   \"entity_id\": \"input_boolean.house_day\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":870,"y":140,"wires":[["1cc8ddde.031232","56c0425.1d1b9bc","ac1e8b4f.578c78"]]},{"id":"e0f5762f.d95948","type":"api-call-service","z":"5f937561.f25ebc","name":"Bedtime to On","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.house_night","data":"{   \"entity_id\": \"input_boolean.house_night\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":860,"y":480,"wires":[["ed84e20.a840f2","5f04d2ed.4db88c","20da7ee2.ecbb52"]]},{"id":"528e21da.dfda8","type":"server-state-changed","z":"5f937561.f25ebc","name":"Carole Home","server":"26d3779.c1c8688","version":1,"entityidfilter":"device_tracker.life360_carole","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":110,"y":480,"wires":[[],["a7974f94.50702"]]},{"id":"e33c6a0b.561368","type":"server-state-changed","z":"5f937561.f25ebc","name":"Mario Home","server":"26d3779.c1c8688","version":1,"entityidfilter":"device_tracker.life360_mario_viamin","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":110,"y":540,"wires":[[],["a7974f94.50702"]]},{"id":"6af47b72.75b244","type":"server-state-changed","z":"5f937561.f25ebc","name":"Nick Home","server":"26d3779.c1c8688","version":1,"entityidfilter":"device_tracker.life360_nicolas_viamin","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":100,"y":600,"wires":[[],["a7974f94.50702"]]},{"id":"30824f73.63b39","type":"server-state-changed","z":"5f937561.f25ebc","name":"Lalou Home","server":"26d3779.c1c8688","version":1,"entityidfilter":"device_tracker.life360_alexandra_viamin","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":110,"y":660,"wires":[[],["a7974f94.50702"]]},{"id":"769dd45a.60fcfc","type":"server-state-changed","z":"5f937561.f25ebc","name":"Vic Home","server":"26d3779.c1c8688","version":1,"entityidfilter":"device_tracker.life360_victoria_viamin","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":100,"y":720,"wires":[[],["a7974f94.50702"]]},{"id":"c7bf82f1.68751","type":"comment","z":"5f937561.f25ebc","name":"Based on time","info":"","x":110,"y":100,"wires":[]},{"id":"ed84e20.a840f2","type":"api-call-service","z":"5f937561.f25ebc","name":"Normal Day to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_day","data":"{   \"entity_id\": \"input_boolean.house_day\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1170,"y":460,"wires":[[]]},{"id":"5f04d2ed.4db88c","type":"api-call-service","z":"5f937561.f25ebc","name":"Evening to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_evening","data":"{   \"entity_id\": \"input_boolean.house_evening\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1160,"y":520,"wires":[[]]},{"id":"20da7ee2.ecbb52","type":"api-call-service","z":"5f937561.f25ebc","name":"Away to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_away","data":"{   \"entity_id\": \"input_boolean.house_away\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1150,"y":580,"wires":[[]]},{"id":"1cc8ddde.031232","type":"api-call-service","z":"5f937561.f25ebc","name":"Night to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_night","data":"{   \"entity_id\": \"input_boolean.house_night\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1150,"y":20,"wires":[[]]},{"id":"56c0425.1d1b9bc","type":"api-call-service","z":"5f937561.f25ebc","name":"Evening to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_evening","data":"{   \"entity_id\": \"input_boolean.house_evening\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1160,"y":80,"wires":[[]]},{"id":"ac1e8b4f.578c78","type":"api-call-service","z":"5f937561.f25ebc","name":"Away to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_away","data":"{   \"entity_id\": \"input_boolean.house_away\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1150,"y":140,"wires":[[]]},{"id":"f0f998b9.7d77c8","type":"time-range-switch","z":"5f937561.f25ebc","name":"Between 5:30AM and 11PM","lat":"37.1135","lon":"-121.992","startTime":"5:30","endTime":"23:00","startOffset":0,"endOffset":0,"x":420,"y":700,"wires":[["b31bcc84.385d8"],["e0f5762f.d95948"]]},{"id":"74140a28.773fb4","type":"server-state-changed","z":"5f937561.f25ebc","name":"Bedtime is toggled on","server":"26d3779.c1c8688","version":1,"entityidfilter":"input_boolean.house_night","entityidfiltertype":"exact","outputinitially":false,"state_type":"habool","haltifstate":"true","halt_if_type":"bool","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":920,"y":560,"wires":[["ed84e20.a840f2","5f04d2ed.4db88c","20da7ee2.ecbb52"],[]]},{"id":"fde2f05b.90048","type":"server-state-changed","z":"5f937561.f25ebc","name":"Normal Day  is toggled on","server":"26d3779.c1c8688","version":1,"entityidfilter":"input_boolean.house_day","entityidfiltertype":"exact","outputinitially":false,"state_type":"habool","haltifstate":"true","halt_if_type":"bool","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":930,"y":200,"wires":[["1cc8ddde.031232","56c0425.1d1b9bc","ac1e8b4f.578c78"],[]]},{"id":"19aeb4aa.47ae5b","type":"api-call-service","z":"5f937561.f25ebc","name":"Evening to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_evening","data":"{   \"entity_id\": \"input_boolean.house_evening\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1160,"y":740,"wires":[[]]},{"id":"b31bcc84.385d8","type":"time-range-switch","z":"5f937561.f25ebc","name":"Between 5:30AM and sunset","lat":"37.1135","lon":"-121.992","startTime":"5:30","endTime":"sunset","startOffset":0,"endOffset":0,"x":440,"y":540,"wires":[["b6beb32c.2792b"],["859aef2d.ab775"]]},{"id":"859aef2d.ab775","type":"api-call-service","z":"5f937561.f25ebc","name":"Evening to On","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.house_evening","data":"{   \"entity_id\": \"input_boolean.house_evening\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":860,"y":300,"wires":[["e4f4194c.cda8f8","d612a037.1aaae","9a40eb51.b255e8"]]},{"id":"6b137983.945628","type":"bigtimer","z":"5f937561.f25ebc","outtopic":"","outpayload1":"ON","outpayload2":"OFF","name":"Sunset-11PM Timer","comment":"","lat":"37.1135","lon":"-121.992","starttime":"5004","endtime":"1380","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"ON","outtext2":"OFF","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":190,"y":260,"wires":[["299e8137.26bf0e"],[],[]]},{"id":"299e8137.26bf0e","type":"switch","z":"5f937561.f25ebc","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"OFF","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":340,"wires":[["71957424.d00dbc"],["4359adc8.410a94"]]},{"id":"e4f4194c.cda8f8","type":"api-call-service","z":"5f937561.f25ebc","name":"Normal Day to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_day","data":"{   \"entity_id\": \"input_boolean.house_day\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1170,"y":260,"wires":[[]]},{"id":"d612a037.1aaae","type":"api-call-service","z":"5f937561.f25ebc","name":"Night to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_night","data":"{   \"entity_id\": \"input_boolean.house_night\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1150,"y":320,"wires":[[]]},{"id":"9a40eb51.b255e8","type":"api-call-service","z":"5f937561.f25ebc","name":"Away to Off","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_away","data":"{   \"entity_id\": \"input_boolean.house_away\" }","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"flow","mustacheAltTags":false,"x":1150,"y":380,"wires":[[]]},{"id":"98da7fa9.774b","type":"server-state-changed","z":"5f937561.f25ebc","name":"Evening is toggled on","server":"26d3779.c1c8688","version":1,"entityidfilter":"input_boolean.house_evening","entityidfiltertype":"exact","outputinitially":false,"state_type":"habool","haltifstate":"true","halt_if_type":"bool","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":920,"y":360,"wires":[["9a40eb51.b255e8","d612a037.1aaae","e4f4194c.cda8f8"],[]]},{"id":"616fdb21.183f94","type":"server-state-changed","z":"5f937561.f25ebc","name":"Away is toggled on","server":"26d3779.c1c8688","version":1,"entityidfilter":"input_boolean.house_away","entityidfiltertype":"exact","outputinitially":false,"state_type":"habool","haltifstate":"true","halt_if_type":"bool","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":910,"y":740,"wires":[["45bb5a5f.c39834","19aeb4aa.47ae5b","9824dc47.49b27"],[]]},{"id":"a7974f94.50702","type":"ha-get-entities","z":"5f937561.f25ebc","server":"26d3779.c1c8688","name":"How many are home ?","rules":[{"property":"entity_id","logic":"is","value":"device_tracker.life360_*","valueType":"re"},{"property":"state","logic":"is","value":"home","valueType":"str"}],"output_type":"array","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":340,"y":880,"wires":[["7b5ac19c.b12af"]]},{"id":"7b5ac19c.b12af","type":"switch","z":"5f937561.f25ebc","name":"Someone in","property":"payload","propertyType":"msg","rules":[{"t":"nempty"},{"t":"empty"}],"checkall":"true","repair":false,"outputs":2,"x":550,"y":880,"wires":[["9f5a64a8.086038"],["540b3fb.77ba1c","bdae643f.ae50c8"]]},{"id":"b50f5b7c.a47158","type":"inject","z":"5f937561.f25ebc","name":"ON","topic":"msg.payload","payload":"True","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":980,"wires":[["a7974f94.50702"]]},{"id":"540b3fb.77ba1c","type":"api-call-service","z":"5f937561.f25ebc","name":"Turn On House Empty","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.house_empty","data":"{ \"entity_id\" : \"input_boolean.house_empty\" }","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":882,"y":882,"wires":[[]]},{"id":"9f5a64a8.086038","type":"api-call-service","z":"5f937561.f25ebc","name":"Turn Off House Empty","server":"26d3779.c1c8688","version":1,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.house_empty","data":"{ \"entity_id\" : \"input_boolean.house_empty\" }","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":500,"y":800,"wires":[["f0f998b9.7d77c8"]]},{"id":"72e90d12.816444","type":"api-current-state","z":"5f937561.f25ebc","name":"House is not empty","server":"26d3779.c1c8688","version":1,"outputs":2,"halt_if":"false","halt_if_type":"bool","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.house_empty","state_type":"habool","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":590,"y":100,"wires":[["b6beb32c.2792b"],["bdae643f.ae50c8"]]},{"id":"71957424.d00dbc","type":"api-current-state","z":"5f937561.f25ebc","name":"House is not empty","server":"26d3779.c1c8688","version":1,"outputs":2,"halt_if":"false","halt_if_type":"bool","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.house_empty","state_type":"habool","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":590,"y":240,"wires":[["859aef2d.ab775"],["bdae643f.ae50c8"]]},{"id":"4359adc8.410a94","type":"api-current-state","z":"5f937561.f25ebc","name":"House is not empty","server":"26d3779.c1c8688","version":1,"outputs":2,"halt_if":"false","halt_if_type":"bool","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.house_empty","state_type":"habool","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":590,"y":380,"wires":[["e0f5762f.d95948"],["bdae643f.ae50c8"]]},{"id":"2e4f0991.ee6186","type":"comment","z":"5f937561.f25ebc","name":"Based on Presence","info":"","x":110,"y":420,"wires":[]},{"id":"26d3779.c1c8688","type":"server","z":"","name":"Home Assistant"}]
One word of advise I can give (as I use home assistants bison sensor for home and away) is be carefull pasting your rednode code, as mine contained my HASS password, thankfully I caught it and changed the password and then the pasted code !
Have you tried this?
```json
Your code here
Yes, that did it ! Thanks @mbonani. I have updated my OP to add the code.
Not 100% sure but you have stated Day/Evening/Bedtime okay
How does your house change in those 3 ?
You’ve also stated home/not_home, how does that change things ?
Generally the case statements do not overlap
As people run their heating/cooling on home/not_home
And the lights on day segment
But surely not_home either drops these off OR it also runs randomised lights to make the house appear occupied (but only when dark).
None of this (as far as I’m aware) will fit neatly into 4 catagories.
I think you need to approach this from different angles depending on what you wish to achieve. This leads to smaller goals that are easier to achieve and can be built upon over time.
Incorporate Music, External lights only on when sun is below the horizon, is there a door switch that could bring a light on ? etc.
This seems like a very compelte flow, I’ve tried using it, but It seems the house_empty doesn’t do anything for me, so it never switches to house_away. Not using the 360 tracker, but the integrated device tracker. Tried fixing it but with no result, any suggestions?
It’s been over a year and my flow has changed a bit since then, but let me try and help. When you say house_empty does not do anything, what do you mean ? Have you set up the “input_boolean.house_empty” ? Does it not get triggered by the flow ? Does it get triggered but no action is happening after that ?
Thanks for your reply, I’ve found your flow to be very comprehensive so I wanted to use it for myself. Thank you for sharing. I’ve set up the boolean, but it never seems to be triggered when nobody is home. It’s just that the node where it checks if the house is empty, does nothing and it always keeps set to day/evening/etc.
Not sure what goes wrong w/o further detail. My flow works as intended : there is 5 of us, each time one of our statuses change, the “get entities” node counts how many are home, sends the number to the switch. If it is zero then a service call is made to turn on the boolean. If its not zero then the boolean, stays on off (or is turned to off)…can you paste your flow ?
Found it, the Emtpy results checkbox was off in my flow. Strange because I never changed that. Seems to work now. Thanks for helping me out with the screenshot. :smiley:
