"Please help me create an automation. Right now, almost everything works correctly, but there is an issue with changing the state of zone.home from, for example, 3 to 1, as the automation is also triggered.
In general, I want the trigger to be a change in the home zone. If all residents leave the home, I want to receive a notification. If one person returns home, I want it to first turn on the outside lights, but only if it’s after sunset. Then, it should turn on the interior lights, but only after the main door is opened, and this should also happen after sunset.
I’ve tried various combinations, but it always activates the automation when changing the zone.home state to 1, even from 2 or 3 to 1."
- id: "2522788646735623"
alias: Światło On po powrocie do domu
description: ""
- platform: state
entity_id:
- zone.home
condition:
- condition: template
value_template: "{{ is_state('input_select.dom_select', 'Auto') }}"
- if:
value_template: "{{ states('zone.home') | float < 1 }}" # Home = 0
then:
- service: notify.facebook_text_giebek
message: Nikogo nie ma w domu - po powrocie powinno włączyć się światło
else:
- if:
value_template: "{{ states('zone.home') | float == 1 }}" # Home = 1
# - condition: template
# value_template: "{{ states('zone.home') | float > 0 and states('zone.home') | float < 2 }}"
value_template: "{{ is_state('sun.sun', 'below_horizon') }}" # słońce jest poniżej horyzontu.
value_template: "{{ ((as_timestamp(now()) - as_timestamp(trigger.from_state.last_changed)) | int ) > 5 }}"
then:
- if:
value_template: "{{ is_state('light.swiatlo_podbitka_przod', 'off') or is_state('light.swiatlo_podbitka_wykusz', 'off')}}"
then:
- service: light.turn_on
entity_id:
- light.swiatlo_podbitka_przod
- light.swiatlo_podbitka_wykusz
brightness_pct: 10
- wait_for_trigger:
- platform: state
entity_id: binary_sensor.drzwi_wejsciowe_contact
to: "on"
timeout: "00:00:10"
continue_on_timeout: false
transition: 10
color_name: red
brightness_pct: 100
entity_id: light.yeelink_bslamp1_fb60_light
transition: 10
color_name: white
brightness_pct: 100
entity_id: light.hst
transition: 20
effect: Day
kelvin: 3000
brightness_pct: 20
entity_id:
- light.yeelink_ceilc_c7c1_light
message: Świtło On po powrocie do domu - test
mode: restart
That’s because you have used a State trigger without defined to or from configuration variables. When you do that, the trigger fires every time the entity’s state or any of its attributes update. In the case of a zone entity, that means every person entering the zone will cause the automation to fire 2 times. Once for the state change, and once for the change to the persons attribute.
When you’re interested in whether a state’s value crosses a threshold rather than lands on a specific value, use Numeric state triggers…
description: ""
- platform: numeric_state
entity_id:
- zone.home
below: 1
entity_id:
- zone.home
above: 0
condition:
- choose:
- conditions:
- condition: trigger
sequence:
- conditions:
sequence:
entity_id:
brightness_pct: 10
- wait_for_trigger:
- platform: state
to: "on"
timeout: "00:00:10"
transition: 10
color_name: red
brightness_pct: 100
transition: 10
color_name: white
brightness_pct: 100
transition: 20
effect: Day
kelvin: 3000
brightness_pct: 20
entity_id:
mode: single
Thank you for your response. You changed the mode to single , which, in the case of a state change during the automation, had 00:00:10 set for testing purposes, but the final value will be 10 minutes.
- wait_for_trigger:
- platform: state
to: "on"
timeout: "00:10:00"
In HA, the Choose action existed for a while before the If/Then action was added. So, a lot of us who have been around since then are just in the habit of using Choose.
Choose allows more than just then/else branching without requiring nesting.
Please, I need one more help. I enjoy making automations more challenging :P.
Is it possible to make it so that after detecting motion, the program resets back to counting down somewhere around 25 minutes
description: ""
entity_id:
- zone.home
below: 1
entity_id:
- zone.home
above: 0
condition:
- choose:
- conditions:
sequence:
- delay: "00:00:05"
message: Za 25 minut światło powinno się wyłączyć.
- delay: "00:25:00"
- service: homeassistant.turn_off
entity_id: light.wszystkie_swiatla
- service: media_player.turn_off
entity_id:
- media_player.lazienka_2
- if:
value_template: "{{ is_state('media_player.lg_salon', 'on') }}"
then:
- service: automation.turn_off
entity_id: automation.paski_led_on_off
- service: scene.create
scene_id: wled_tv_mem
snapshot_entities: light.lg_tv
entity_id:
- light.lg_tv
brightness_pct: 100
color_name: red
effect: Blink
- service: number.set_value
entity_id:
- number.lg_tv_speed
value: "200"
- wait_template: "{{ is_state('binary_sensor.wszystkie_czujniki_pir', 'on') }}"
timeout: 300
- if:
- "{{ wait.completed }}" # - "{{ not wait.completed }}"
then:
- service: automation.trigger
skip_condition: false
entity_id: automation.wylacz_wszystkie_swiatla
message: Automatyzacja działa - TV został wyłączony!!!!!!!!!!!!!!!!!!!!
else:
entity_id:
- media_player.lg_salon
- delay:
seconds: 2
- service: scene.turn_on
entity_id: scene.wled_tv_mem
- service: automation.turn_on
message: Wszystkie światła i media zostały wyłączone.
- conditions:
sequence:
entity_id:
brightness_pct: 10
- wait_for_trigger:
- platform: state
to: "on"
timeout: "00:10:00"
- delay: "00:00:02"
transition: 100
color_name: white
brightness_pct: 1
- delay: "00:00:08"
transition: 100
color_name: white
brightness_pct: 1
- delay: "00:00:14"
transition: 30
effect: Day
kelvin: 3000
brightness_pct: 30
entity_id:
mode: restart
There wasn’t a specific topic, but now the automation works well. It rarely happens, but when my wife and I leave the apartment, the kids can continue watching TV. In the near future, they will get phones and integrate them with HA. For now, school is more important :).
If someone notices an error in the code or has a suggestion to improve the code, please write to me.
