LED brightness depending on Sensor
Hi
i have got a LED, a motion sensor und a brightness sensor.
The LED tunrs on when motion is detected.
I want the brightness of the LED to be dependend on the brightness sensor.
(255 - brightness sensor)
examples:
  • Motion detected, Brighness: 255, LED brightness: 0
  • Motion detected, Brighness 155, LED brighness 100
LED:
light:
  - platform: mqtt
    state_topic: "dev/1/dev_led/state/power"
    command_topic: "dev/1/dev_led/command/power"
    brightness_state_topic: "dev/1/dev_led/state/brightness"
    brightness_command_topic: "dev/1/dev_led/command/brightness"
    brightness_scale: 255
    qos: 0
    payload_on: "1"
    payload_off: "0"
    optimistic: false
Motion
binary_sensor:
  platform: mqtt
  state_topic: "dev/1/motion"
  qos: 0
  payload_on: "on"
  payload_off: "off"
Brightness (Potentiometer for testing)
- platform: mqtt
    state_topic: "dev/1/pot"
    unit_of_measurement: ""
Automation
  - alias: "Hallway Motion"
      platform: state
      entity_id: binary_sensor.arbeitszimmer_motion
      to: 'on'
      service: homeassistant.turn_on
      entity_id:
        - light.dev_led
  - alias: "Hallway Timer"
      platform: state
      to: "off"
      for:
        seconds: 10
      service: homeassistant.turn_off
      entity_id: light.dev_led
I want something like this:
     platform: state
     to: 'on'
     service: light.turn_on
     entity_id:
       - light.dev_led
       brightness: sensor.pot
Posting with correct formatting will allow people to better help you.
Please highlight your code, then use the pre-formatted text button in the editor as shown below:
     platform: state
     to: 'on'
     entity_id:
       - light.dev_led
     data_template:
       brightness: '{{ 255 - (states("sensor.pot") | int) }}'
@taces2
can you post your yaml config and report how things are working. I am also looking for that kind of coding
This is my working automation.
I haven’t change the light or sensor component from the first post.
I added the automation “led_nach_sensor” so that the brightness changes when the state of the sensor changes
   automation:
          platform: state
          to: 'on'
          data_template:
          platform: state
          to: "off"
          for:
            seconds: 10
      - alias: "led_nach_sensor"
          platform: state
          entity_id: sensor.pot
        condition:
          condition: state
          state: "on"
          data_template:
I am going to add an input select
“auto” or “manuell”
so i can manually change the led if i don’t want the automation
for example when i start a scene like “movie”
