I have a aeotec z wave light bulb multi color level zwa002 which cannot be turned off. I have hass on docker v0.106.6.
Inclusion goes well.
After inclusion I can turn it off by the switch in the frontend.
In the evening the light turns on by an automation rule.
When I go to sleep the light should be turned off by an automation rule as all other lights however this does not happen. And also I cannot turn it off in the frontend. The switch goes to the off position and then quickly goes to the on position again.
I did several inclusion and exclusions
The OZW_log I cannot understand well but I do not see errors at first sight.
The light is in a good mesh and has 18 neighbours.
Any suggestion where to troubleshoot?
Or is the light DOA?
The bulb is dimmable. I tried this as well but it does not go to 0%. 15% works. But if I set it to 0% it dims a small percentage and then quickly returns to the original level
Good find! It looks a bit difficult to implement because I think I then have to switch to ozw 1.6. For now I use just the ozw included in homeassistant 0.107. If i switch to a higher version I am scared that my whole z wave setup fails…
