Hi all!
I just started using Home-Assistant and I love it so far!
With nearly unlimited possibilitys an Idea popped up if it would be possible to control a specific LED-Strip with it.
Poorly I do not have the Informations about the manufacturer or the specific model…
I´ve tried to link it anyways and did a little researching and found out that the controler uses a HF-LPB100 Chip.
With this Information i came a little further and was able to auto detect the Controler via Home Assistant with following entry in the configuration.yaml:
light:
- platform: flux_led
automatic_add: true
After restart I can see that a device was found with the correct IP Address but it is greyed out and I´m not able to Control it.
I know the Informations are extremly rare with missing Informations about manufacturer etc. but hopefully someone could give further input on what to try next or how to receive more needed informations or even how to solve my problem.
If it helps as an indicator… The Controler was casting an own Wifi before I linked it to my iot network - SSID was something like “EasyLighting…”
There are some updates coming to the flux_led integration but they aren’t integrated into the core of HA yet.
They can be installed as a custom component for the time being. You would need to download the files from the PR and put them in your custom_components folder under a sub-folder called flux_led and the system will pick up the custom / new code in place of the built-in integration.
Thanks for your answer!
I´ve tried your suggested steps but still same behavior.
Just to be sure I´ve done this right (like mentoined I´m new to Home Assistant) and the new version from flux_led was loaded correct…
Create a sub folder in the same directory as the configuration.yaml called flux_led and copy the files from Git in there without any other sub dir like the core right?
Means a path like “…/custom_components/flux_led/”
If I filter on Add Integration for something like Flux or LED it is not showing up.
What exactly do you mean by it is supposed to import my yaml configuration?
Do I have to add another specific line in there?
Currently - regarding to Flux - I just have the autodetect Block like mentoined in my first posting.
Once it is installed it should import the configuration from the YAML and move it into the Integrations page. You don’t need the entry in configuration.yaml once it is installed.
You may want to go from the PR to my repository and grab the entire flux_led folder for that branch to make sure you get all the files. I’m running it as a custom component and it is working on mine.
Maybe paste a screen shot of the custom_components/flux_led folder.
My god I´m so sorry I´m an Idiot and copied the full Pull from git in the custom Components.
Now with the files in components\flux_led to the correct dir I do have the Icon in the Integration Configuration.
New Behaviour: I do not see the Light anymore even with auto detect also tried to enter the IP Address manually with the Integration UI but the Device still do not seem to appear.
Also not in Configuration -> Devices
Is there anything else to try on this point?
Sorry again! Like mentoined I´m brand new with Home Assistant basically first day
How you got further with your LED strip working with HF-LPB100 ?
I have a power plug from CHACON using same chip.
How can I hook up this in Home assistant?
