lazloman
(Lorenzo THurman)
June 1, 2021, 6:51pm
1
I have two dimmers, a Zooz ZEN31 and a Qubino ZMNHWD. I can’t get either one to work with HA. I’ve used the Zooz and two others before, with OpenHAB and they worked just fine. They include/exclude from zwavejsmqtt without any issue, but I can never get the strip to light up. No errors in the logs. I can measure there is power getting to the strip. For both dimmers, the devices are setup like this:
None of those switches turn on the light and none allow for adjusting the color temperature. I’ve gone through the exclude/include cycle with these any number of times, I’m at a loss.
Any ideas appreciated.
HassIO 2021.5.5
zwavejs2mqtt 0.18.1
firstof9
(firstof9)
June 1, 2021, 11:18pm
2
What happens if you attempt to control the LEDs from the zwavejs2mqtt control panel?
lazloman
(Lorenzo THurman)
June 2, 2021, 1:12am
3
If you mean by performing a level change up? Then yes, for both dimmers.
firstof9
(firstof9)
June 2, 2021, 1:21am
4
Are you able to set the colors via zwavejs2mqtt?
lazloman
(Lorenzo THurman)
June 2, 2021, 2:11am
5
Yes, that I can do. I can also set the temperature (cool/warm white). The strip just never turns on.
firstof9
(firstof9)
June 2, 2021, 2:35am
6
Set the zwave-js logging to silly in the control panel and post your logs when you attempt to adjust the strip.
lazloman
(Lorenzo THurman)
June 2, 2021, 4:40am
7
Thanks for the help. The node of interest is 78:
2021-06-02T04:37:56.461Z DRIVER » [Node 078] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 49
└─[MultiChannelCCCommandEncapsulation]
│ source: 0
│ destination: 3
└─[SupervisionCCGet]
│ session id: 23
│ request updates: true
└─[MultilevelSwitchCCSet]
target value: 255
2021-06-02T04:37:56.485Z SERIAL « [ACK] (0x06)
2021-06-02T04:37:56.490Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:37:56.492Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:56.499Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:37:56.519Z SERIAL « 0x010500133100d8 (7 bytes)
2021-06-02T04:37:56.522Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:56.524Z DRIVER « [REQ] [SendData]
callback id: 49
transmit status: OK
2021-06-02T04:37:56.560Z SERIAL « 0x010c0004001a063105030a0009df (14 bytes)
2021-06-02T04:37:56.565Z CNTRLR [Node 026] [Multilevel Sensor] Illuminance: metadata updated [Endpoint 0]
2021-06-01 23:37:56.568 INFO ZWAVE: Node 26: metadata updated: 49-0-Illuminance
2021-06-02T04:37:56.572Z CNTRLR [Node 026] [~] [Multilevel Sensor] Illuminance: 9 => 9 [Endpoint 0]
2021-06-01 23:37:56.574 INFO ZWAVE: Node 26: value updated: 49-0-Illuminance 9 => 9
2021-06-02T04:37:56.576Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:56.578Z DRIVER « [Node 026] [REQ] [ApplicationCommand]
└─[MultilevelSensorCCReport]
type: Illuminance
scale: Lux
value: 9
2021-06-02T04:37:56.605Z SERIAL « 0x010f0004004e09600d03006c0297010326 (17 bytes)
2021-06-02T04:37:56.607Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:56.608Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 3
│ destination: 0
└─[SupervisionCCReport]
session id: 23
more updates follow: true
status: Working
duration: 3s
2021-06-02T04:37:57.404Z SERIAL » 0x011200134e0b600d00046c0198032601ff2532eb (20 bytes)
2021-06-02T04:37:57.413Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 50
│ source: 0
│ destination: 4
│ session id: 24
target value: 255
2021-06-02T04:37:57.437Z SERIAL « [ACK] (0x06)
2021-06-02T04:37:57.441Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:37:57.441Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:57.442Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:37:57.457Z SERIAL « 0x010500133200db (7 bytes)
2021-06-02T04:37:57.458Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:57.460Z DRIVER « [REQ] [SendData]
callback id: 50
transmit status: OK
2021-06-02T04:37:57.497Z SERIAL « 0x010f0004004e09600d04006c029801032e (17 bytes)
2021-06-02T04:37:57.501Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:57.505Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 4
│ destination: 0
session id: 24
status: Working
duration: 3s
2021-06-02T04:37:58.461Z SERIAL » 0x011200134e0b600d00056c0199032601ff2533ea (20 bytes)
2021-06-02T04:37:58.477Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 51
│ source: 0
│ destination: 5
│ session id: 25
target value: 255
2021-06-02T04:37:58.492Z SERIAL « [ACK] (0x06)
2021-06-02T04:37:58.496Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:37:58.497Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:58.498Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:37:58.514Z SERIAL « 0x010500133300da (7 bytes)
2021-06-02T04:37:58.516Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:58.517Z DRIVER « [REQ] [SendData]
callback id: 51
transmit status: OK
2021-06-02T04:37:58.553Z SERIAL « 0x010f0004004e09600d05006c029901032e (17 bytes)
2021-06-02T04:37:58.564Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:58.565Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 5
│ destination: 0
session id: 25
status: Working
duration: 3s
2021-06-02T04:37:59.540Z SERIAL « 0x010f0004004e09600d03006c0217ff005b (17 bytes)
2021-06-02T04:37:59.550Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:59.559Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 3
│ destination: 0
session id: 23
more updates follow: false
status: Success
duration: 0s
2021-06-02T04:37:59.561Z CNTRLR « [Node 078] Received update for a Supervision session
2021-06-02T04:37:59.563Z SERIAL » 0x010d00134e06600d000326022534f2 (15 bytes)
2021-06-02T04:37:59.564Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 52
│ source: 0
│ destination: 3
└─[MultilevelSwitchCCGet]
2021-06-02T04:37:59.582Z SERIAL « [ACK] (0x06)
2021-06-02T04:37:59.588Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:37:59.589Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:59.590Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:37:59.600Z SERIAL « 0x010500133400dd (7 bytes)
2021-06-02T04:37:59.601Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:59.609Z DRIVER « [REQ] [SendData]
callback id: 52
transmit status: OK
2021-06-02T04:37:59.750Z SERIAL « 0x010f0004004e09600d03002603181800f8 (17 bytes)
2021-06-02T04:37:59.757Z CNTRLR [Node 078] [~] [Multilevel Switch] targetValue: 255 => 24 [Endpoint 3]
2021-06-01 23:37:59.765 INFO ZWAVE: Node 78: value updated: 38-3-targetValue 255 => 24
2021-06-02T04:37:59.767Z CNTRLR [Node 078] [~] [Multilevel Switch] duration: {"value":0,"unit":"s [Endpoint 3]
econds"} => {"value":0,"unit":"seconds"}
2021-06-01 23:37:59.768 INFO ZWAVE: Node 78: value updated: 38-3-duration 0s => 0s
2021-06-02T04:37:59.769Z CNTRLR [Node 078] [~] [Multilevel Switch] currentValue: 0 => 24 [Endpoint 3]
2021-06-01 23:37:59.770 INFO ZWAVE: Node 78: value updated: 38-3-currentValue 0 => 24
2021-06-02T04:37:59.771Z SERIAL » [ACK] (0x06)
2021-06-02T04:37:59.776Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 3
│ destination: 0
└─[MultilevelSwitchCCReport]
current value: 24
target value: 24
duration: 0s
2021-06-02T04:38:00.500Z SERIAL « 0x010f0004004e09600d04006c0218ff0053 (17 bytes)
2021-06-02T04:38:00.505Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:00.512Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 4
│ destination: 0
session id: 24
status: Success
duration: 0s
2021-06-02T04:38:00.519Z CNTRLR « [Node 078] Received update for a Supervision session
2021-06-02T04:38:00.529Z SERIAL » 0x010d00134e06600d000426022535f4 (15 bytes)
2021-06-02T04:38:00.530Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 53
│ source: 0
│ destination: 4
2021-06-02T04:38:00.554Z SERIAL « [ACK] (0x06)
2021-06-02T04:38:00.559Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:38:00.560Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:00.562Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:38:00.588Z SERIAL « 0x010500133500dc (7 bytes)
2021-06-02T04:38:00.590Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:00.607Z DRIVER « [REQ] [SendData]
callback id: 53
transmit status: OK
2021-06-02T04:38:00.634Z SERIAL « 0x010f0004004e09600d04002603636300ff (17 bytes)
2021-06-02T04:38:00.643Z CNTRLR [Node 078] [~] [Multilevel Switch] targetValue: 255 => 99 [Endpoint 4]
2021-06-01 23:38:00.646 INFO ZWAVE: Node 78: value updated: 38-4-targetValue 255 => 99
2021-06-02T04:38:00.648Z CNTRLR [Node 078] [~] [Multilevel Switch] duration: {"value":0,"unit":"s [Endpoint 4]
2021-06-01 23:38:00.651 INFO ZWAVE: Node 78: value updated: 38-4-duration 0s => 0s
2021-06-02T04:38:00.661Z CNTRLR [Node 078] [~] [Multilevel Switch] currentValue: 0 => 99 [Endpoint 4]
2021-06-01 23:38:00.661 INFO ZWAVE: Node 78: value updated: 38-4-currentValue 0 => 99
2021-06-02T04:38:00.665Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:00.667Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 4
│ destination: 0
current value: 99
target value: 99
duration: 0s
2021-06-02T04:38:01.549Z SERIAL « 0x010f0004004e09600d05006c0219ff0053 (17 bytes)
2021-06-02T04:38:01.559Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:01.564Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 5
│ destination: 0
session id: 25
status: Success
duration: 0s
2021-06-02T04:38:01.568Z CNTRLR « [Node 078] Received update for a Supervision session
2021-06-02T04:38:01.591Z SERIAL » 0x010d00134e06600d000526022536f6 (15 bytes)
2021-06-02T04:38:01.594Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 54
│ source: 0
│ destination: 5
2021-06-02T04:38:01.629Z SERIAL « [ACK] (0x06)
2021-06-02T04:38:01.634Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:38:01.635Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:01.645Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:38:01.650Z SERIAL « 0x010500133600df (7 bytes)
2021-06-02T04:38:01.652Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:01.662Z DRIVER « [REQ] [SendData]
callback id: 54
transmit status: OK
2021-06-02T04:38:01.699Z SERIAL « 0x010f0004004e09600d05002603636300fe (17 bytes)
2021-06-02T04:38:01.701Z CNTRLR [Node 078] [~] [Multilevel Switch] targetValue: 255 => 99 [Endpoint 5]
2021-06-01 23:38:01.703 INFO ZWAVE: Node 78: value updated: 38-5-targetValue 255 => 99
2021-06-02T04:38:01.707Z CNTRLR [Node 078] [~] [Multilevel Switch] duration: {"value":0,"unit":"s [Endpoint 5]
2021-06-01 23:38:01.712 INFO ZWAVE: Node 78: value updated: 38-5-duration 0s => 0s
2021-06-02T04:38:01.714Z CNTRLR [Node 078] [~] [Multilevel Switch] currentValue: 0 => 99 [Endpoint 5]
2021-06-01 23:38:01.715 INFO ZWAVE: Node 78: value updated: 38-5-currentValue 0 => 99
2021-06-02T04:38:01.718Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:01.720Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 5
│ destination: 0
current value: 99
target value: 99
duration: 0s
2021-06-02T04:38:03.795Z SERIAL » 0x011200134e0b600d00016c019a032601ff2537e9 (20 bytes)
2021-06-02T04:38:03.807Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 55
│ source: 0
│ destination: 1
│ session id: 26
target value: 255
2021-06-02T04:38:03.826Z SERIAL « [ACK] (0x06)
2021-06-02T04:38:03.831Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:38:03.832Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:03.836Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:38:03.848Z SERIAL « 0x010500133700de (7 bytes)
2021-06-02T04:38:03.849Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:03.855Z DRIVER « [REQ] [SendData]
callback id: 55
transmit status: OK
2021-06-02T04:38:03.886Z SERIAL « 0x010f0004004e09600d01006c029a010329 (17 bytes)
2021-06-02T04:38:03.889Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:03.890Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 1
│ destination: 0
session id: 26
status: Working
duration: 3s
2021-06-02T04:38:05.113Z SERIAL » 0x011200134e0b600d00026c019b032601ff2538e4 (20 bytes)
2021-06-02T04:38:05.124Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 56
│ source: 0
│ destination: 2
│ session id: 27
target value: 255
2021-06-02T04:38:05.144Z SERIAL « [ACK] (0x06)
2021-06-02T04:38:05.149Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:38:05.150Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:05.151Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:38:05.164Z SERIAL « 0x010500133800d1 (7 bytes)
2021-06-02T04:38:05.165Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:05.166Z DRIVER « [REQ] [SendData]
callback id: 56
transmit status: OK
2021-06-02T04:38:05.203Z SERIAL « 0x010f0004004e09600d02006c029b01032b (17 bytes)
2021-06-02T04:38:05.205Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:05.206Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 0
session id: 27
status: Working
duration: 3s
2021-06-02T04:38:07.295Z SERIAL « 0x010f0004004e09600d01006c021aff0054 (17 bytes)
2021-06-02T04:38:07.306Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:07.308Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 1
│ destination: 0
session id: 26
status: Success
duration: 0s
2021-06-02T04:38:07.311Z CNTRLR « [Node 078] Received update for a Supervision session
2021-06-02T04:38:07.317Z SERIAL » 0x010d00134e06600d000126022539fd (15 bytes)
2021-06-02T04:38:07.321Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 57
│ source: 0
│ destination: 1
2021-06-02T04:38:07.355Z SERIAL « [ACK] (0x06)
2021-06-02T04:38:07.357Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:38:07.357Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:07.364Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:38:07.372Z SERIAL « 0x010500133900d0 (7 bytes)
2021-06-02T04:38:07.376Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:07.381Z DRIVER « [REQ] [SendData]
callback id: 57
transmit status: OK
2021-06-02T04:38:07.405Z SERIAL « 0x010f0004004e09600d01002603636300fa (17 bytes)
2021-06-02T04:38:07.407Z CNTRLR [Node 078] [~] [Multilevel Switch] targetValue: 255 => 99 [Endpoint 1]
2021-06-01 23:38:07.407 INFO ZWAVE: Node 78: value updated: 38-1-targetValue 255 => 99
2021-06-02T04:38:07.408Z CNTRLR [Node 078] [~] [Multilevel Switch] duration: {"value":0,"unit":"s [Endpoint 1]
2021-06-01 23:38:07.410 INFO ZWAVE: Node 78: value updated: 38-1-duration 0s => 0s
2021-06-02T04:38:07.411Z CNTRLR [Node 078] [~] [Multilevel Switch] currentValue: 0 => 99 [Endpoint 1]
2021-06-01 23:38:07.413 INFO ZWAVE: Node 78: value updated: 38-1-currentValue 0 => 99
2021-06-02T04:38:07.413Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:07.417Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 1
│ destination: 0
current value: 99
target value: 99
duration: 0s
2021-06-02T04:38:08.574Z SERIAL « 0x010f0004004e09600d02006c021bff0056 (17 bytes)
2021-06-02T04:38:08.581Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:08.587Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 0
session id: 27
status: Success
duration: 0s
2021-06-02T04:38:08.592Z CNTRLR « [Node 078] Received update for a Supervision session
2021-06-02T04:38:08.600Z SERIAL » 0x010d00134e06600d00022602253afd (15 bytes)
2021-06-02T04:38:08.602Z DRIVER » [Node 078] [REQ] [SendData]
│ callback id: 58
│ source: 0
│ destination: 2
2021-06-02T04:38:08.628Z SERIAL « [ACK] (0x06)
2021-06-02T04:38:08.629Z SERIAL « 0x0104011301e8 (6 bytes)
2021-06-02T04:38:08.634Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:08.638Z DRIVER « [RES] [SendData]
was sent: true
2021-06-02T04:38:08.648Z SERIAL « 0x010500133a00d3 (7 bytes)
2021-06-02T04:38:08.648Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:08.652Z DRIVER « [REQ] [SendData]
callback id: 58
transmit status: OK
2021-06-02T04:38:08.720Z SERIAL « 0x010f0004004e09600d020026034a4a00f9 (17 bytes)
2021-06-02T04:38:08.726Z CNTRLR [Node 078] [~] [Multilevel Switch] targetValue: 255 => 74 [Endpoint 2]
2021-06-01 23:38:08.729 INFO ZWAVE: Node 78: value updated: 38-2-targetValue 255 => 74
2021-06-02T04:38:08.733Z CNTRLR [Node 078] [~] [Multilevel Switch] duration: {"value":0,"unit":"s [Endpoint 2]
2021-06-01 23:38:08.734 INFO ZWAVE: Node 78: value updated: 38-2-duration 0s => 0s
2021-06-02T04:38:08.740Z CNTRLR [Node 078] [~] [Multilevel Switch] currentValue: 0 => 74 [Endpoint 2]
2021-06-01 23:38:08.743 INFO ZWAVE: Node 78: value updated: 38-2-currentValue 0 => 74
2021-06-02T04:38:08.747Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:08.748Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 0
current value: 74
target value: 74
duration: 0s
2021-06-02T04:38:09.129Z SERIAL « 0x0110000400500a32022174000000000000d4 (18 bytes)
2021-06-02T04:38:09.140Z CNTRLR [Node 080] [~] [Meter] value[66049]: 0 => 0 [Endpoint 0]
2021-06-01 23:38:09.143 INFO ZWAVE: Node 80: value updated: 50-0-value-66049 0 => 0
2021-06-02T04:38:09.144Z SERIAL » [ACK] (0x06)
2021-06-02T04:38:09.146Z DRIVER « [Node 080] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
time delta: 0 seconds
firstof9
(firstof9)
June 2, 2021, 1:39pm
8
Looks like the zwave side is working properly as far as I can tell.
Are you sure the LED strip isn’t damaged?
lazloman
(Lorenzo THurman)
June 2, 2021, 5:14pm
9
Yes, but I can try another that is currently working with OpenhHAB. I’ll try later and get back.
