LED Night Light Controller Help
Greetings… I wrote the code below quite some time back, and whilst I know it’s not perfect it has done the job in our 8 year old daughters bedroom.
Our daughter has been asking lately if I can tweak the program to have the lights come on at bedtime around 9pm at 20% brightness so the room is not dark. And when the PIR detects any movement during the night the lights increase to 70 or 80% brightness, and then go back to 20% brightness when the PIR doesn’t detect any movement.
I will admit I am not the greatest yaml programmer, so perhaps this is a good time to revamp the code, add the new features our daughter is seeking, and perhaps simplify the code based on some recommendations from the gurus in this forum.
Here’s the current code…
substitutions:
  off_hour: '5'
esp8266:
 board: d1_mini
 framework:
  version: recommended
esphome:
  on_boot:
    - light.turn_off:
        transition_length: 2.5s
status_led:
  pin: GPIO2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "<REDACTED>"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp4-Bdrmlights Fallback Hotspot"
captive_portal:
script:
  - id: turn_off
    mode: restart
    then:
      - delay: 90s
      - light.turn_off:
          transition_length: 7.5s
      - logger.log: "LED lights are OFF"
binary_sensor:
  - platform: gpio
    pin: D5
    name: "Bdrm PIR Sensor"
    device_class: motion
    on_press:
      then:
      - if:
          condition:
            and:
              # If it's night time
              - sun.is_below_horizon:
              - lambda: |-
                  auto hour = id(my_time).now().hour;
                  return hour > 12 || hour < ${off_hour};
          then:
              #Turn on the LED lights
              - light.turn_on:
                  brightness: 40%
                  effect: random
              - logger.log: "LED lights are ON"
    on_release:
      - script.execute: turn_off
sun:
  latitude: !secret latitude
  longitude: !secret longitude
time:
  platform: homeassistant
  timezone: !secret timezone
  on_time:
  - hours: ${off_hour}
    minutes: 0
    seconds: 0
    then:
    - light.turn_off:
light:
  - platform: neopixelbus
    variant: WS2812
    pin: D1
    num_leds: 54
    type: GRB
    name: "FastLED WS2812B Light"
    default_transition_length: 7.5s
    effects:
      # Use default parameters:
      - random:
      - random:
          name: "Slow Random Effect"
          transition_length: 30s
          update_interval: 20s
      - random:
          name: "Fast Random Effect"
          transition_length: 4s
          update_interval: 5s
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
      - pulse:
          # transition_length: 1s      # defaults to 1s
          update_interval: 2s
      - addressable_rainbow:
          speed: 10
          width: 50
      - addressable_color_wipe:
          name: "Color Wipe Effect"
          colors:
            - red: 10%
              green: 90%
              blue: 25%
              num_leds: 5
            - red: 35%
              green: 15%
              blue: 60%
              num_leds: 1
          add_led_interval: 100ms
          reverse: false
      - addressable_fireworks:
          update_interval: 32ms
          spark_probability: 10%
          use_random_color: true
          fade_out_rate: 120
      - addressable_scan:
      - addressable_scan:
          move_interval: 100ms
          scan_width: 5
      - addressable_random_twinkle:
          name: Random "Twinkle Effect"
          twinkle_probability: 15%
          progress_interval: 32ms
I was thinking I could just set a timer based on the position of the sun… i.e. so when the sun is below the horizon the lights come on at 20% brightness. But I am not sure how I might integrate that into the existing code?
Here’s something I thought I might be able to use…
sun:
  on_sunset:
  - elevation: -10°
    then:
    - light.turn_on:
I am sure there’s a much better way to do this… so any ideas/tips appreciated.
Still trying to make it work… haven’t been able to figure out multiple light triggers under different circumstances.
This code doesn’t work, so will keep trying options. Code highlighted with ** is my attempt at having the LED lights come on at 9pm, dimmed to 10%, and in red color only.
substitutions:
  off_hour: '5'
  on_hour: '9'
esp8266:
 board: d1_mini
 framework:
esphome:
  on_boot:
    - light.turn_off:
status_led:
  pin: GPIO2
# Enable logging
logger:
  level: DEBUG
api:
ota:
wifi:
  ap:
captive_portal:
script:
  - id: turn_off
    mode: restart
    then:
      - delay: 90s
      - light.dim_relative:
          relative_brightness: 10%
          transition_length: 0.1s
      - logger.log: "LED lights are Dimmed"
binary_sensor:
  - platform: gpio
    pin: D5
    on_press:
      then:
      - if:
          condition:
            and:
              - lambda: |-
          then:
              - light.turn_on:
                  brightness: 40%
                  effect: random
    on_release:
sun:
time:
  on_time:
    minutes: 0
    seconds: 0
    then:
    - light.turn_off:
 **time:**
**  platform: homeassistant**
**  timezone: !secret timezone**
**  id: bdrm_on_time  **
**  on_time:**
**  - hours: ${on_hour}**
**    minutes: 0**
**    seconds: 0**
**    then:**
**    - light.turn_on:**
**        id: bdrm_led_lights**
**        brightness: 10%**
**        red: 100%**
**    - logger.log: "LED lights are Dimmed"**
light:
    variant: WS2812
    pin: D1
    num_leds: 54
    type: GRB
    effects:
      - random:
      - random:
      - random:
          update_interval: 5s
      - pulse:
      - pulse:
      - pulse:
          update_interval: 2s
          speed: 10
          width: 50
          colors:
            - red: 10%
              green: 90%
              blue: 25%
              num_leds: 5
            - red: 35%
              green: 15%
              blue: 60%
              num_leds: 1
          reverse: false
          fade_out_rate: 120
      - addressable_scan:
      - addressable_scan:
          scan_width: 5
One of the awesome gurus on ESPHome discord gave me this code… but not being a C++ person I am unsure how to integrate it into my yaml. The idea behind this code is to simplify the entire yaml, and just use time of day rather than sunrise/sunset approach.
binary_sensor:
    lambda: |-
      auto now = id(my_time).now();
      if (!now.is_valid())
        return {};
      int hour = now.hour;
      return ((hour > ${on_hour}) && (hour < ${off_hour}));
I think I am just going to start from scratch :laughing:
Took a radical approach… based on the code I was given.
binary_sensor:
# New code for turning lights on/off
    lambda: |-
        return {};
    on_hour:
      - light.turn_on:
          brightness: 40%
          effect: random
    off_hour:
      - light.turn_off
Only… it complains about this section?
    off_hour:
      - light.turn_off
Specifically the id: bdrm_led_lights
Missing a colon after light.turn_off
Thank for the feedback… turns out the code is quite wrong… having had some feedback from the ESPHome discord. Back to the drawing board :joy:
