Hi all,
I just can’t work this one out, and it is probably something obvious however I have a tuya generic light switch with 2 buttons / 2 status LEDs and one tuya generic power point and again with 2 buttons and 2 status LEDs… The power point works fine and both status LEDs fade in and out nicely which is what I am trying to achieve on the switch. On the switch though, I can only get LED 1 to fade in and out nicely with LED the other switching on / off instantly.
I originally used ITChipTool to create the yaml and the only difference I can see between both YAML’s is the light platform ( monochromatic / binary ) and the output platform (libretiny_pwm / gpio ). The power point has monochromatic and libretiny_pwm in both light and output platforms respectively and is working fine. The issue is, if I try it on the switch, the second LED stops working altogether. Help! lol I just can’t work out where I am going wrong! Thank you in advance for taking the time to at least read this!
This works with LED one fading nicely and LED 2 instant:
light:
- platform: monochromatic
output: output_led_1
- platform: binary
output: output_led_2
output:
- platform: libretiny_pwm
pin:
number: P26
inverted: false
- platform: gpio
pin:
number: P11
inverted: false
This still works for LED 1, LED 2 is now unresponsive:
light:
output:
pin:
number: P26
inverted: false
pin:
number: P11
inverted: false
My entire YAML with LED 1 working and LED 2 unresponsive:
substitutions:
device_name: esphome_test_switch
friendly_name: ESPHome - Test Switch
esphome:
friendly_name: ${friendly_name}
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.206
gateway: 192.168.1.1
subnet: 255.255.255.0
dns1: 192.168.1.1
ap:
ssid: ${device_name}AP
password: !secret globe_ap_password
logger:
web_server:
captive_portal:
mdns:
api:
encryption:
key: !secret globe_api_key
ota:
password: !secret globe_ota_password
button:
- platform: restart
bk72xx:
board: generic-bk7231n-qfn32-tuya
light:
output:
pin:
number: P26
inverted: false
pin:
number: P11
inverted: false
binary_sensor:
- platform: status
- platform: gpio
pin:
number: P20
inverted: true
mode: INPUT_PULLUP
on_press:
then:
- switch.toggle: switch_1
- platform: gpio
pin:
number: P7
inverted: true
mode: INPUT_PULLUP
on_press:
then:
- switch.toggle: switch_2
switch:
- platform: gpio
pin: P6
on_turn_on:
- light.turn_on: light_switch_1
on_turn_off:
- light.turn_off: light_switch_1
- platform: gpio
pin: P8
on_turn_on:
- light.turn_on: light_switch_2
on_turn_off:
- light.turn_off: light_switch_2
status_led:
pin:
number: P22
inverted: true
My power point YAML which is working fine:
substitutions:
device_name: esphome_kitchen_power_point_2
friendly_name: ESPHome - Kitchen Power Point 2
esphome:
wifi:
manual_ip:
static_ip: 192.168.1.127
dns1: 192.168.1.1
ap:
api:
encryption:
ota:
logger:
web_server:
captive_portal:
mdns:
button:
- platform: restart
bk72xx:
output:
pin:
number: P24
inverted: true
pin:
number: P6
inverted: true
light:
binary_sensor:
- platform: status
- platform: gpio
pin:
number: P9
inverted: true
mode: INPUT_PULLUP
on_press:
then:
- platform: gpio
pin:
number: P7
inverted: true
mode: INPUT_PULLUP
on_press:
then:
switch:
- platform: gpio
pin: P26
on_turn_on:
on_turn_off:
- platform: gpio
pin: P14
on_turn_on:
on_turn_off:
status_led:
pin: P8
