Hi, I would like to make LED strip light controlled by HA and wall switch. And my requirement is - switch have to work even if HA is down = switch is controling power to light strip.
I want to use somethink like magic led controler or H801 RGBW LED flashed with esphome.
I see two possible sollution:
control over some smart relay (for examle esphome/rassberry relay or shelly or sonoff). I draw schema - v1
this should be working, but I see problem with controls over HA. There will be two entites - relay and controler and I would have to pair them somehow. -
control directly led controller. This should be also possible. I would use TX or RX pin as digital input. something like V2 on image
Maybe is better use wled and esp board and use normal pin as input.
Which solution is better? Do you have any others ideas?
thanks
