I’m sorry for posting such a simple question here, but I’m having a really difficult time wrapping my head around this new topic.
I want a simple led strip for my man cave, so behind display, possible as indirect light on top of shelves.
I read a few topics here and googled this, but many solutions require soldering or separate ESPs, but I’m more interested in a plug and play solution. I’d prefer a WiFi solution. Zigbee isn’t working properly for me (don’t ask).
I have several Shelly RGBW relays in use with fairly inexpensive DC power supply units and bulk RGBW LED strips off Amazon. It is super easy to wire them up and integrates well with HA - no soldering or programming required. I found this to be a better solution than the all-in-one controller+led strip products because much less expensive and no proprietary vendor app silliness.
Note:
If your credentials for the add-on don’t work, simply use the API Key you’ll need anyway - cost me about an hour of my life to get that one sorted out
This power supply that I paired with these LED strips were for an uplight project I did in a couple places (above kitchen cabinets and on top of big entertainment center) about 3 years ago. Yes, the Shelly relays are just laying on top of the cabinets next to the power bricks.
Too clarify, you won’t cut the pet supply wires to use the adapter @mombro indicated. However, you will need short wires to run from + terminal of Shelly to + terminal of adapter; then same for - terminal.
If you want to cut the wires of power supply as @Hellis81 suggested, you can and just connect directly to Shelly + and - terminals without adapter.
Jumper cables no!, AC cables are ok or whatever cable that have enough copper inside…
ps. you don’t need that adaptor, just cut the wires and use common screw connectors… or wire it directly to shelly screw connectors.
