I have a led strip that i would dim.
If i look at the dasboard of homeassistant the slider have a resolution off 255 setpoints.
in ESPhome i can only set 0-100% this resolution is to big for me.
The light strip is there to simulate a sunrise and sunset in a aquarium.
in between 38% and 39% there a 3 extra steps in HASS, why can’t i setbrightness like in HASS (from 0-255) ?
Need some advice in this
and my esp configuration:
output:
- platform: ledc
pin: GPIO4
light:
- platform: monochromatic
output: pwm_output
default_transition_length: 0s
gamma_correct: 5
switch:
name: "Dummy switch Aquarium"
internal: true
lambda: |-
return (id(aquarium).current_values.is_on());
on_turn_on:
then:
- light.turn_on:
brightness: 16.0%
