Hi, i’m running hass 0.39.3 on LEDE(owrt) - not using virtualenv obviously.
i’ve compiled netifaces, and installed it via opkg, i can manually import it so that seems to work.
i’ve installed netdisco via pip3 install netdisco, python3 -m netdisco and reports my devices just fine.
yet when I run hass it insists on re-installing netdisco
17-03-28 21:42:04 INFO (<concurrent.futures.thread.ThreadPoolExecutor object at 0x11ad520>_8) [homeassistant.util.package] Attempting install of netdisco==0.9.1
Command “/usr/bin/python3.6 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-09opml76/netifaces/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(’\r\n’, ‘\n’), file, ‘exec’))” install --record /tmp/pip-07qlmdih-record/install-record.txt --single-version-externally-managed --compile --home=/tmp/tmpg16vmvio” failed with error code 1 in /tmp/pip-build-09opml76/netifaces/
17-03-28 21:44:35 ERROR (<concurrent.futures.thread.ThreadPoolExecutor object at 0x11ad520>_8) [homeassistant.bootstrap] Not initializing discovery because could not install dependency netdisco==0.9.1
I can work around this by launching hass with --skip-pip but would rather have hass behave as it was designed to. Any hints on what’s wrong here?
thanks!
