I bought while ago a led panel:
The solution is built on Tuya and I integrated in Home Assistant. But many time the light is not reacting.
I tried out Tuya Convert - Tasmota but was not working.
The led panel is powered by Ledtu (www.ledtu.com) Smart LED Light Driver:
Datasheet: QE系列 智能照明隔离无频闪驱动器 - 乐图科技·Ledtu Tech
The inside:
Show that TYWE2S is used. (Used google to translate the page)
From Potential Wireless Flash for EKAZA Smart Plug 16A - TYWE2S - MCU V1.1.7? · Issue #1096 · ct-Open-Source/tuya-convert · GitHub I got know how to flash it.
Problem the IO0 is on the back side and blocked by the Elko. I had to desolder the TYWE2S to flash it.
I flashed it with ESP Home and that is my configuration:
light:
- platform: cwww
cold_white: output_component1
warm_white: output_component2
cold_white_color_temperature: 6500 K
warm_white_color_temperature: 3000 K
gamma_correct: 0.0
# Example output entry
output:
- platform: esp8266_pwm
pin: GPIO14
pin: GPIO12
There is some mireds the led panel doesn’t like.
