I am a bit confused about the http legacy passwords. I know that it’s being depreciated, but do I remove
http: api_password: !secret http_api_password
and add under homeassistant in the configuration.yaml file?
auth_providers: - type: legacy_api_password api_password: !secret http_password
You are not alone. Let’s wait what will be in the release notes tomorrow. https://rc.home-assistant.io/blog/2019/10/14/release-101/
Yes that’s what I did and I seems to work fine. Tho if your still using other http: parts don’t remove that part, and don’t add a second homeassistant: part
I had som strange goings on when I had two entry’s for homeassistant:
You’ll get strange goings on if you have two entries for anything in your yaml file!
