BramNH
(Bram Nijenhuis)
May 23, 2024, 9:11am
1
Because I don’t have a 3D printer (yet), and was thinking of a cool and convenient way to deploy a voice assistant. LEGO is a cool alternative to 3D printing to build a casing, but definitely not cheap! The servo movement sound gives you confirmation that the wake word is detected and is very helpful when you are not able to see the lights of the ATOM echo. But I also made sure you can see the lights of the ATOM echo through the front, so you can see when VAD starts and stops.
It looks really nice on the shelf! However it’s just a fun project . The ATOM echo is not a premium product, so this voice assistant (in terms of microphone/speaker hardware) is far off the standards of Google and Alexa.
I am combining this with local AI, which works a lot better when the command is misheard from a distance. (The demo video above is using the default HA Conversation agent).
I have setup a relatively fast, fully local, AI voice assistant for Home Assistant.
The guide below is written for installation with a Nvidia GPU on a Linux machine. But it is also possible to use AMD GPUs and Windows. Feel free to share any info or ask any question related to Assist.
The following components are used:
Wyoming Faster Whisper Docker container (build files )
Llama-cpp-python Docker container (build files )
Extended OpenAI HACS Integration (modified fork )
Functionary Small V2.4 LL…
The R2D2 Voice Assistant is based on this demo video .
markyskus
(Markyskus)
July 10, 2024, 12:58pm
2
This is awesome, are you using the m5stack for controlling the servo or using a second ESP modul?
BramNH
(Bram Nijenhuis)
July 10, 2024, 1:55pm
3
Thanks! The servo is connected to the Atom Echo, so no extra ESP used.
markyskus
(Markyskus)
July 10, 2024, 2:55pm
4
Could you please share the ESP config, I couldn’t handled it.
either the sound or the servo works, but not at the same time
BramNH
(Bram Nijenhuis)
July 10, 2024, 2:59pm
5
Will do when I find the time! (Hopefully tomorrow)
BramNH
(Bram Nijenhuis)
July 11, 2024, 5:39pm
7
esphome:
name_add_mac_suffix: false
friendly_name: M5Stack Atom Echo 226060
project:
version: "1.0"
min_version: 2023.11.1
############# Tried to add a R2D2 reaction after wakeword detected, but speaker cant be used ##########
# includes:
# - r2d2.h
esp32:
board: m5stack-atom
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "kcExnLd4TyDcQ3OD9jF/FnsNTNjme4UFxjw96Xx1nuw="
ota:
password: "e6b40e3f40f1434978f0113da5246078"
dashboard_import:
package_import_url: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
wifi:
ssid: !secret wifi_ssid
on_connect:
- delay: 5s # Gives time for improv results to be transmitted
- ble.disable:
on_disconnect:
- ble.enable:
ap:
ssid: "M5Stack-Atom-Echo"
password: "KXDLC8pEgAFK"
captive_portal:
improv_serial:
esp32_improv:
authorizer: none
# Using ledc output to control a standard 50Hz RC servo over the normal 1 to 2 mS pulse range
output:
- platform: ledc
pin: GPIO21
frequency: 50 Hz
min_power: 5.0% # 5% at 50Hz is 1mS (20mS cycles)
max_power: 10.0% # 10% at 50Hz is 2mS (20mS cycles)
number:
optimistic: true
min_value: 0
max_value: 100
step: 1
on_value:
- then:
- lambda: !lambda |-
id(servo).set_level(x / 100);
button:
- platform: factory_reset
i2s_audio:
i2s_lrclk_pin: GPIO33
i2s_bclk_pin: GPIO19
microphone:
- platform: i2s_audio
i2s_din_pin: GPIO23
adc_type: external
pdm: true
speaker:
i2s_dout_pin: GPIO22
dac_type: external
mode: mono
voice_assistant:
microphone: echo_microphone
speaker: echo_speaker
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 2.0
vad_threshold: 3
on_wake_word_detected:
- output.set_level:
level: 50%
# - speaker.play:
# id: echo_speaker
# data: !lambda return r2d2_excited;
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 100%
effect: "Slow Pulse"
on_stt_vad_end:
- light.turn_on:
blue: 100%
red: 0%
green: 100%
effect: "Fast Pulse"
on_tts_start:
- light.turn_on:
blue: 100%
red: 0%
green: 100%
brightness: 100%
effect: none
- output.set_level:
level: 0%
- delay: 500ms
- output.set_level:
level: 100%
on_end:
- delay: 100ms
- wait_until:
not:
speaker.is_playing:
- script.execute: reset_led
on_error:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 100%
effect: none
- delay: 1s
on_client_connected:
- if:
condition:
switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
on_client_disconnected:
- if:
condition:
then:
- voice_assistant.stop:
- light.turn_off: led
binary_sensor:
- platform: gpio
pin:
number: GPIO39
inverted: true
disabled_by_default: true
entity_category: diagnostic
on_multi_click:
- timing:
- ON for at least 250ms
- OFF for at least 50ms
then:
- if:
condition:
switch.is_off: use_wake_word
then:
- if:
condition: voice_assistant.is_running
then:
else:
- voice_assistant.start:
else:
- delay: 1s
- script.wait: reset_led
- timing:
- ON for at least 10s
then:
- button.press: factory_reset_btn
light:
- platform: esp32_rmt_led_strip
entity_category: config
pin: GPIO27
default_transition_length: 0s
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
transition_length: 250ms
update_interval: 250ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
script:
- id: reset_led
then:
- if:
condition:
- switch.is_on: use_wake_word
- switch.is_on: use_listen_light
then:
- light.turn_on:
red: 100%
green: 89%
blue: 71%
brightness: 60%
effect: none
else:
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- lambda: id(va).set_use_wake_word(false);
name: Use listen light
optimistic: true
on_turn_on:
on_turn_off:
external_components:
- source: github://pr#5230
components:
- esp_adf
refresh: 0s
esp_adf:
interval:
- interval: 1s
then:
- if:
condition:
api.connected:
then:
- if:
condition:
and:
- not:
then:
sam2332
(Lily Rudloff)
July 12, 2024, 6:26pm
9
How are you doing the r2d2 noises is that a seperate speaker?
BramNH
(Bram Nijenhuis)
July 12, 2024, 6:40pm
10
Nope just the Atom Echo in there. I am using this TTS integration .
phgsbr
(Phgsbr)
July 12, 2024, 9:39pm
11
Thank you so much, @BramNH . Im trying to build myself, your code will be very useful!
ADN182
(ADN182)
September 8, 2024, 6:53pm
12
Hi @BramNH , awesome, I love it !
I buy the same R2-D2 Lego to do it with my son, dou you have some picture of the implementation and link of what you have bought to do it ? (Witch servo ti plug with the atom) ?
Thank in advance !
BramNH
(Bram Nijenhuis)
September 9, 2024, 5:50am
13
Thanks! I will add some pictures to this post this afternoon. I used a SG90 mini servo on which I screwed a flat Lego piece, that could be attached to the inside of the R2 head.
BramNH
(Bram Nijenhuis)
September 9, 2024, 6:09pm
14
I updated the post with pictures of the build
ADN182
(ADN182)
September 11, 2024, 7:45pm
15
Thank a lot, for sharing all that think ! R2-D2 building in progress
Last question about link between sg90 and atom, based on your esphome config you plug the servo on gpio21 like un that picture?
BramNH
(Bram Nijenhuis)
September 11, 2024, 7:49pm
16
Yes indeed, servo is directly plugged into powered by the 5V pin and controlled by GPIO21 of the Atom Echo. Have fun!
mikecoscia
(Mike Coscia)
November 16, 2024, 4:00pm
17
@BramNH hey this is great, I have been trying to integrate a servo with the atom echo for awhile now with no luck. I 3D printed a droid to use as a voice assistant. I gave your code a try, but it is giving me an error message…
INFO ESPHome 2024.10.3
INFO Reading configuration /config/esphome/esphome-web-23e8a4.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
Failed config
ota.unknown: [source /config/esphome/esphome-web-23e8a4.yaml:27]
'ota' requires a 'platform' key but it was not specified.
password: e6b40e3f40f1434978f0113da5246078
BramNH
(Bram Nijenhuis)
November 16, 2024, 6:58pm
18
You need to modify some things to make it work for your microcontroller. OTA password is a unique password for Over The Air updates (this one for my device). Follow the esphome tutorial to get to know more about this.
I also built this on a much older version of ESPHome (maybe 2024.6). So I am not sure if it is directly compatible with your 2024.10
mikecoscia
(Mike Coscia)
November 17, 2024, 1:27am
19
Thanks, I got it up and running! I just removed those few lines and was able to compile and install. Now just have to install it in my droid. Here is the code in case anyone else runs into the issue. Thanks again!
esphome:
friendly_name: Atom Echo - R5 Astromech
project:
version: "1.0"
# includes:
# - r2d2.h
esp32:
board: m5stack-atom
framework:
type: esp-idf
# Enable logging
logger:
api:
ota:
- platform: esphome
dashboard_import:
wifi:
ssid:
password:
on_connect:
- ble.disable:
on_disconnect:
- ble.enable:
ap:
captive_portal:
improv_serial:
esp32_improv:
authorizer: none
output:
- platform: ledc
pin: GPIO21
frequency: 50 Hz
number:
optimistic: true
min_value: 0
max_value: 100
step: 1
on_value:
- then:
button:
i2s_audio:
microphone:
i2s_din_pin: GPIO23
adc_type: external
pdm: true
speaker:
dac_type: external
channel: mono
voice_assistant:
auto_gain: 31dBFS
vad_threshold: 3
- output.set_level:
level: 50%
# - speaker.play:
# id: echo_speaker
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 100%
on_stt_vad_end:
- light.turn_on:
blue: 100%
red: 0%
green: 100%
on_tts_start:
- light.turn_on:
blue: 100%
red: 0%
green: 100%
brightness: 100%
effect: none
- output.set_level:
level: 0%
- delay: 500ms
- output.set_level:
level: 100%
on_end:
- delay: 100ms
- wait_until:
not:
speaker.is_playing:
on_error:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 100%
effect: none
- delay: 1s
- if:
condition:
then:
- if:
condition:
then:
binary_sensor:
- platform: gpio
pin:
number: GPIO39
inverted: true
on_multi_click:
- timing:
then:
- if:
condition:
then:
- if:
then:
else:
else:
- delay: 1s
- timing:
then:
light:
pin: GPIO27
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
min_brightness: 50%
- pulse:
min_brightness: 50%
script:
- id: reset_led
then:
- if:
condition:
then:
- light.turn_on:
red: 100%
green: 89%
blue: 71%
brightness: 60%
effect: none
else:
switch:
name: Use wake word
optimistic: true
on_turn_on:
- if:
condition:
not:
then:
on_turn_off:
optimistic: true
on_turn_on:
on_turn_off:
components:
- esp_adf
refresh: 0s
esp_adf:
interval:
- interval: 1s
then:
- if:
condition:
api.connected:
then:
- if:
condition:
and:
- not:
then:
Hello, friends!
Thanks a lot for this codes… I’m newbee in HA, but I will try to install it on my Atom Echo and my R2D2…
