Hi Everyone,
I have linked through netatmo cloud the only dimmer i have in my house for now.
However, the value of the dimmer seems offset. when i go to the device, and i set to a value, the value in the google home app or app+control app is different. e.g. setting to 51% in homeassistant sets to 89% the dimmer.
How can i solve this issue? i was not able to find the config in order to change the value properly.
Thanks in advance for your help
seems that it is sending something different:
I set the value using the GUI but the log says:
2024-04-12 12:03:53.115 DEBUG (MainThread) [pyatmo.home] Setting state for home (66152b6a1301a4b2b80d60ba) according to {‘modules’: [{‘id’: 00:05:44:00:03:1a:47:38’, ‘brightness’: 5, ‘bridge’: ‘00:01:44:13:a5:26’}]}
2024-04-12 12:03:57.546 DEBUG (MainThread) [pyatmo.home] Setting state for home (66152b6a1301a4b2b80d60ba) according to {‘modules’: [{‘id’: ‘00:05:44:00:03:1a:47:38’, ‘brightness’: 100, ‘bridge’: ‘00:01:44:13:a5:26’}]}
2024-04-12 12:04:02.170 DEBUG (MainThread) [pyatmo.home] Setting state for home (66152b6a1301a4b2b80d60ba) according to {‘modules’: [{‘id’: ‘00:05:44:00:03:1a:47:38’, ‘on’: False, ‘bridge’: ‘00:01:44:13:a5:26’}]}
There is no correlation between what i set in homeassistant and what the netatmo api is sending.
Is someone able to give me a tip where to look?
thank you
