Legrand netatmo cable outlet
I bought a legrand netatmo cable outlet :slight_smile:
It can be controlled as a plug or as “wire pilot”. In the netatmo legrand app it works perfectly, but in the home assistant when I’m in wire pilot mode it doesn’t work. I can only do on\off. But in this mode I have to do: eco\confort\HG…
Does anyone use it like this? If so, how?
Regards,
I have got two of these working with zigbee2mqtt.
Yes i try it on deconz and it works to. But I want to use it on netatmo intégration.
I intregrated my outlel in deconz, I can manage On Off but when I try to read or change the mode, I got a failure error :cry:
I tried to pair it again and again, no success…
(I got one time a timeout error, then I started again to obtain a Failure error.
But the led is green, I don’t understand what I’ve done wrong :cry:
Same here. You have to done it with api request.
Hi Idaho
I have the same issue.
But it’s even worse in my configuration.
If I set up this cable outlet in wire pilot mode in Legrand Control App, then in HA I cannot even use on/off with the Netatmo integration.
It’s only working if I set up this cable outlet without wire pilot, but then Off is switching off the eater and I think it’s not good for the device.
Could you please confirm that you can use at least On/Off in wire mode using the Netatmo integration ?
Thank you
Sorry but no the on\off doesn’t work in wire pilot.
I create a new issue here if someone want to see :slight_smile: Legrand netatmo thermostat entitie doesn't work on deconz · Issue #103462 · home-assistant/core · GitHub
