It would be great to add the Legrand’s hub integration with HA, through the hub’s IP address in the local network. Here is more about the system
@Sylwekss
That would be great!
In the meantime you can connect Legrand’s hub and all the connected devices to HA through the HomeKit Controller. Or you could use Zigbee2MQTT and completely remove the need for the Hub.
