I already read a lot of things regarding zigbee around this forum, however there is one thing that I couldn’t find. I already found topic talking about zigbee, also because one of the most popular brands here uses zigbee, I’m talking about xiaomi.
Someone knows how can I integrate Legrand shutter Switch/Radio-ZigBee ® Niloé with my hassio? Is there some hub that I can use?
In the past I bought a zigbee dongle, but then I was not able to use it (CC2531).
You should be able to pair them to a Zigbee 3.0 hub. You need to remove them from the “Control” application first. Let the switch have permanent red LED and add it using ZHA with the Add new device button. You should see it.
After the initial survey, the device will disconnect and it will become unusable.
To really make it work you need to press the reset button in the switch. The LED will blink in green. Go again to the Add new device screen and you’ll eventually see it again. The LED will turn purple and the switch will work.
