Hello, my first post here, although I’ve been coming here for a year or so to read about different items.
I flashed a lamp with ESPHome. It uses Tuya MCU and it has required a bit of tinkering to find the proper settings. While I flashed slightly different configurations, the RGB+CT light controls disappeared from HA and they refuse to come back. I can only set the lamp mode from the interface. I need help bringing back the light control to the UI.
A bit of background:
I have a couple of lamps I got on different occasions that looked very similar. They are different brands and I bought them at different times. I decided to take a peek to see if I could flash ESPHome on them and found out that the circuits are identical. Same chips and everything: This is what they look like on the inside
They both have a BK72XX module inside (WB3S), which I removed to flash ESPHome. This is my YAML
esphome:
bk72xx:
board: wb3s
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: !secret wifi_ip
gateway: !secret wifi_gateway
subnet: !secret wifi_smask
ap:
ssid: "Fallback Hotspot"
password: "password"
time:
- platform: sntp
timezone: America/New_York
servers:
- pool.ntp.org
captive_portal:
uart:
rx_pin: RX1
tx_pin: TX1
baud_rate: 115200
tuya:
# Datapoint 20: switch (value: ON) Switch ON/OFF
# Datapoint 21: enum (value: 2) Mode {white, color, scene, music}
# Datapoint 22: int value (value: 34) Dimmer
# Datapoint 23: int value (value: 50) Color Temperature
# Datapoint 24: string value (value: hex) HSV
# Datapoint 25: string value (value: JSON) Structure
# Datapoint 26: int value (value: 0) Countdown timer
# Product: '{"p":"owlz2ugyq0mjvdke","v":"1.0.2","m":0}'
time_id: sntp_time
# Control the light
light:
- platform: "tuya"
switch_datapoint: 20
dimmer_datapoint: 22
min_value: 10
max_value: 1000
color_temperature_datapoint: 23
color_temperature_max_value: 1000
cold_white_color_temperature: 7500K
warm_white_color_temperature: 3000K
color_type: hsv
color_datapoint: 24
restore_mode: RESTORE_AND_OFF
select:
- platform: "tuya"
optimistic: true
enum_datapoint: 21
options:
0: white
1: color
2: scene
3: music
As I mentioned before, the light control appeared and controlled the light well through multiple iterations of my trial-and-error process, but then it became unavailable and never came back.
What I have tried so far:
- Deleted the unavailable control from the UI.
- Deleted the ESPHome device and added it again from HA by pasting the YAML. This only brought the mode selector back.
- Looked for unknown/orphan entities without luck
- Flashed a version without any controls to the device and then readded the controls. Only the mode selector came back
- Deleted the device, let HA discover it. Added it again. Only mode selector was added.
- Reloaded HA
- Rebooted HA
The light responds to its buttons and I can see the settings changing in the logs, but I cannot control them from HA. (Other than the mode).
Any help is welcome.
As closing notes, these posts were very helpful for me to get to where I am:
TuyaMCU - Tasmota to get the data point identifiers
(Will add two others as a reply. I am limited as a new user)
