After finding a Sonos one under the tree I looked a bit further in what they had to connect to our in ceiling speakers. Sonos connect seems an option but it lacks a 12v out to switch on the AMP. So I typed in “arduino switch amp on audio in” when I realized that there is a sonos integration.
A home assistant automation that detects the sonos playing to switch on the amp seems so much easier, similarly it will also switch off the amp if the sonos is idle (that probably needs a small delay so it does not switch on/off too often).
Do you have discrete on/off for your amp? The one that I’m connecting now has them, so no need to worry if it’s already on or off. Another amp has a toggle on/off so I’m wondering how to keep track of the fact whether it is on or off?
