Let blueprint generate lovelace-code?
I have created some local blueprints that I use for lighting control, etc. Now I use them for different lights in different rooms, as is the purpose of a blueprint.
As I modified my dashboard accordingly, I realized, that I always have to recreate the same modules with constantly changing sensors. this is time consuming, as yozu have to edit every module or do a massive replace-operation in an external editor.
My idea: when I save the blueprint, the system could generate a standard lovelace code in a display module on the blueprint page, which then can be easily “installed” by copying and pasting.
Would something like that be possible, since the data is stored in the blueprint…?
