I am starting the Home Assistant setup for my home using a Raspberry Pi 3B with Raspbian Stretch Desktop, I already installed the system and I did the setup for external access, but I’m not able to generate the certificate with Let’s Encrypt.
I use a free domain from NO-IP where the IP is renewed directly on the router, I configured the forwarding of ports 80, 443 and 8123 to Raspberry, but when I try to generate the certificate it gives this error:
To test, I removed the firewall rules with the command “sudo iptables -F” and during Certbot verification I accessed the server shown in the screenshot below, but the certificate has not yet been generated.
