Hi, i’m trying to get duckdns and Let’s Encrypt working with Hassio. The issue is, is that my router will only let me forward 443>443 and not 443> 8123. Is there any workaround?
Forward 8123 to 8123. You will need to put https://yourdomain.duckdns.org:8123 when you want to access. The important part being the port specification there (:8123)
The other option is to use a reverse proxy. The NGINX add-on can handle the redirect for you.
Thanks, i’ll give that a go!
