Let's Encrypt addon error
When starting the addon it take a long while and does nothing. In the “Log” panel of the addon i find
Failed to get core_letsencrypt logs, e.call
ApiRaw is not a function. (In ‘e.callApiRaw(“GET”,hassio/${t.includes("_")?addons/${t}:t}/logs${0!==r?/boots/${r}:""},void 0,i?{Range:i}:void 0)’, ‘e.callApiRaw’ is undefined)
Hi Oliver,
Make sure the add-on, HA, Supervisor, and everything else is up to date. You may have a version incompatibility issue somewhere.
You where right, there was one core update missing. After i did that it run’s again. Thanks!
