I made my config completely barebones now…almost nothing is in it. I included logger
…it all looks pretty normal until it gets to this:
17-01-22 18:31:07 homeassistant.components.media_player: Setting up media_player.kodi
17-01-22 18:31:07 homeassistant.components.media_player.kodi: Unable to fetch kodi data
17-01-22 18:31:07 homeassistant.components.media_player: Setting up media_player.samsungtv
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 138, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 98, in create_connection
raise err
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 88, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 361, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.4/http/client.py", line 1090, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 163, in connect
conn = self._new_conn()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 147, in _new_conn
self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x6f91aa70>: Failed to establish a new connection: [Errno 111] Connection refused
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 363, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.11', port=8080): Max retries exceeded with url: /jsonrpc (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6f91aa70>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/home/hass/.homeassistant/deps/jsonrpc_requests/jsonrpc.py", line 37, in send_request
response = self.request(data=request_body)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 535, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 487, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.11', port=8080): Max retries exceeded with url: /jsonrpc (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6f91aa70>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/media_player/kodi.py", line 110, in _get_players
return self._server.Player.GetActivePlayers()
File "/home/hass/.homeassistant/deps/jsonrpc_requests/jsonrpc.py", line 112, in __call__
return self.__request_method(self.__method_name, args, kwargs)
File "/home/hass/.homeassistant/deps/jsonrpc_requests/jsonrpc.py", line 96, in __request
return self.send_request(method_name, is_notification, args or kwargs)
File "/home/hass/.homeassistant/deps/jsonrpc_requests/jsonrpc.py", line 39, in send_request
raise TransportError('Error calling method %r' % method_name, requests_exception)
jsonrpc_requests.jsonrpc.TransportError: ("Error calling method 'Player.GetActivePlayers'", ConnectionError(MaxRetryError("HTTPConnectionPool(host='192.168.0.11', port=8080): Max retries exceeded with url: /jsonrpc (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6f91aa70>: Failed to establish a new connection: [Errno 111] Connection refused',))",),))
17-01-22 18:31:07 homeassistant.core: Bus:Handling <Event state_changed[L]: old_state=None, entity_id=media_player.samsung_smart_tv, new_state=<state media_player.samsung_smart_tv=unknown; supported_media_commands=1337, is_volume_muted=False, friendly_name=Samsung Smart TV @ 2017-01-22T18:31:07.924835+01:00>>
17-01-22 18:31:07 homeassistant.core: Bus:Handling <Event state_changed[L]: old_state=None, entity_id=media_player.kodi, new_state=<state media_player.kodi=off; supported_media_commands=4927, friendly_name=KODI @ 2017-01-22T18:31:07.941209+01:00>>
17-01-22 18:31:07 homeassistant.components.media_player.samsungtv: Samsung TV 192.168.0.21:55000 added as 'Samsung Smart TV'
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=volume_up, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=media_play, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=media_next_track, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_on, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=media_stop, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=media_pause, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_off, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=media_play_pause, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=clear_playlist, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=toggle, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=volume_down, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=media_previous_track, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=volume_set, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=volume_mute, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=media_seek, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=select_source, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=play_media, domain=media_player>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event component_loaded[L]: component=media_player>
17-01-22 18:31:08 homeassistant.core: Starting Home Assistant core loop
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event homeassistant_start[L]>
17-01-22 18:31:08 root: Pilight receiver thread started
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=power_on, domain=hdmi_cec>
17-01-22 18:31:08 homeassistant.core: Timer:starting
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=standby, domain=hdmi_cec>
17-01-22 18:31:08 homeassistant.core: Bus:Handling <Event service_registered[L]: service=select_device, domain=hdmi_cec>
17-01-22 18:31:08 netdisco.service: Scanning
Connection refused?
