Let's Encrypt Domain
In the Let’s Encrypt config
What should the Let’s Encrypt “domain” be if…
A) Installed to Pi from hass.io
B) Accepted all defaults
What is the domain name I should be typing in?
I feel like an idiot asking this.
My url is…
http://hassio:8123/hassio/addon/core_letsencrypt
You type in the domain you’re using - the one your HA system is accessed with from the Internet.
If you haven’t yet set that up, then you probably don’t yet have a domain to use. You should look at DuckDNS - and the DuckDNS add-on also handles Let’s Encrypt for you.
A domain name that you own.
Thank you.
I’m using Nabu Casa.
Do I even need Let’s Encrypt?
Thanks.
No, you only need Let’s Encrypt if you want direct remote access, with either a domain you own, or through a service like DuckDNS.
'Thank you!
