Simplicity itself to follow bar the fact the front end doesn’t come back when restarting!
Only error from log…
2017-09-28 12:25:30 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 422, in start
resp = yield from self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web.py", line 304, in _handle
handler = yield from factory(app, handler)
File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro
res = func(*args, **kw)
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 19, in auth_middleware
if app['hass'].http.api_password is None:
AttributeError: 'HomeAssistant' object has no attribute 'http'
It says api_password is None but there is one, any ideas?
Hey @Bobby_Nobble I noticed that someone above you in the original post had issues. After forwarding port 443 > Hassio’s 8123 it worked. Have you tried that? Where are you trying to reach your front end?
This may be a stupid question but are you removing http: from your config file or just the ssl lines?
My RPi3 comes in tomorrow so I’ve been doing some research on getting this setup. I’m hoping it will be as straight forward as that blog entry makes it sound,
Tried every combo going of port forwarding, not port forwarding and adding port to config etc etc and it fails with the error above so the front end is not going to appear regardless.
duckdns is fine, I was using it previously but updating via my server, but the add-on is doing the job. It’s literally the let’s encrypt bit in the config yaml that does it…
http:
# Uncomment this to add a password (recommended!)
api_password: xxxxxxxx
# Uncomment this if you are using SSL or running in Docker etc
# base_url: xxxxxx.duckdns.org:8123
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
Every combo going, if you read the comments with the post you’ll see some rather important detail about the ports got left out but I still can’t get mine to work which is doubly annoying because everything else people have a lot of trouble with just seems to work for me!
So I got my RPi3 with Hass.io up and running. I tried setting up DuckDNS and Let’s Encrypt using that same blog post, following the instructions exactly. The only thing I did that wasn’t mentioned was adding my DuckDNS token and address. I’m having a different issue than you though - Hass.io loads up fine even with the ssl entires in my config file but when I try to go to http://myaddress.duckdns.org:8123, it doesn’t work (looks like it’s loading for a while then basically gives me a page not found). The weird part is I think Let’s Encrypt is working fine because the only way I can access my Hass.io is using https://hassio.local:8123.
I did not forward any ports because my understanding is you shouldn’t have to based on what that blog post says…
No more errors, I can see it is doing the certificates properly, and I now have to use https to get into the front end locally BUT Chrome doesn’t like the certificate and bleats about the site being insecure if you force it to let you in.
Externally, still nothing whatever I try, no forwarding, forwarding to different ports etc etc, same as @shred
@Bobby_Nobble Thanks for sharing your config.
My config was about the same - I’ve been playing with variants of the base_url, and nothing seemed to change. I’m wondering if that’s even required? I would assume that line would be included in the instructions on the HA official docs if it was?
I’ve still got the same problem as you, as far as my-subdomain.duckdns.org port forwarding doesn’t work as expected. I think that’s probably a router config problem. You don’t happen to be using a Linksys Smart Wi-Fi system?
Where would you put the 8123 that Paulus mentioned was missing from the instructions to avoid port forwarding if not there? When I add tried adding it to the DuckDNS config it got upset.
