I’m trying to use let’s encrypt (without DuckDNS) but I keep getting the following error.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] file-structure.sh: executing...
[cont-init.d] file-structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[17:27:03] INFO: Selected http verification
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for homeassistant.redacted.com
Waiting for verification...
Challenge failed for domain homeassistant.redacted.com
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: homeassistant.redacted.com
Type: unauthorized
Detail: Invalid response from
http://homeassistant.redacted.com/.well-known/acme-challenge/7WKvuROIEZl0oAgbe-chF5r2gU6lt4CwTsHhaLnPr0w
[2607:f1c0:100f:f000::2c7]: 204
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
This is my configuration for Let’s Encrypt.
email: [email protected]
domains:
- homeassistant.redacted.com
certfile: fullchain.pem
keyfile: privkey.pem
challenge: http
dns: {}
My external URL is https://homeassistant.redacted.com
Currently I have port forwarding set to
80 => 80
443 => 443
8123 => 8123
Based on other posted I’ve tried a number of things. For my external URL I’ve tried https and http. I tried appending :80 and :8123. For port forwarding I’ve tried 443 => 8123 and 443 => 80.
One comment in a post suggested putting the port for the external URL on a separate line in configuration.yaml. However, I’m not sure if the port should be 80, 443, or 8123. More importantly, I have no idea the syntax to use in configuration.yaml. So far I’ve just used the GUI.
Can someone help?
Thanks,
Skye
