Let's encrypt issue
Hey there, I’m having an issue getting let’s encrypt working.
I am getting this error when I connect using the duckDNS address (through Chrome):
This site can’t provide a secure connection
xxxxxx.duckdns.org didn’t accept your login certificate, or one may not have been provided.
Try contacting the system admin.
ERR_BAD_SSL_CLIENT_AUTH_CERT
And the pi’s IP give’s this error (through Chrome):
This site can’t be reached
The connection was reset.
The HASS log is also empty.
I can connect locally via the pi’s IP address to home assistant if I remove the HTTP lines in the config.
Any Ideas?
All of the certificates have 755 permission (I also tried 777 but no luck)
Make sure that the HA user is the group/owner of the cert files and directories.
@rpitera I created the certificates with the pi user.
What should I do so that I can change the owner or the certificate?
(Newbie speaking here)
depending on who made the certificate
if root then sudo chown homeassistant:homeassistant filename assuming HA’s user is homeassistant
if made by any other user then as the user you can just chown homeassistant:homeassistant filename
it’s usually just easier to do it as sudo
thanks
But HA still not working.
Still getting:
Safari can’t open the page “https://removed.duckdns.org/”. The error is: “The server “removed.duckdns.org” did not accept the certificate.” (NSURLErrorDomain:-1205)
Figured it out myself. I just had to forward port 8123 to 8123 instead of 443 to 8123.
One minus, I need to type :8123 after the URL
Once you update the cert, you can switch back to your previous port forwarding. Also - you probably have port 80 aimed at HA - you can turn that off after updating the cert.
Hi, can anyone help me out, I am getting this error but I’m not sure what Cert has expired? I have been into DuckDNS and I can’t see any issues?
