I have a bit of a weird setup but bottom line is i’m trying to renew my certificates for https. Running hassio and using the addon for Let’s Encrypt. When I click the start button it spins blue once and then turns Red.
Looking at the system log I have these status related
20-04-16 21:08:45 INFO (SyncWorker_12) [supervisor.docker.interface] Clean addon_core_letsencrypt application
20-04-16 21:08:46 ERROR (SyncWorker_12) [supervisor.docker] Can't start addon_core_letsencrypt: 500 Server Error: Internal Server Error ("driver failed programming external connectivity on endpoint addon_core_letsencrypt (3b9e5c360dac84050d166316a4429de731ea1ddf725fd65c62a9f0edf4db1bcc): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use")
