Thank you, solved my problem also.
Debian 18.04 and Hass.IO
Hello everyone,
I am not having Linux but directly Hassio on my Raspberry 4.
I am having the same issue and I don’t know how to solve it.
I fixed the IP and DNS address using the my_network
file and a USB stick but I am not sure of what I should put in the DNS section.
I haven’t configured any port routing yet on my router.
[ipv4]
method=manual
address=192.168.1.17/24;192.168.1.1
dns=192.168.1.1;8.8.8.8;
And here is what I put in configuration.yaml
file:
http:
base_url: !secret my_base_url
server_port: 8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 3
Hi, you have found a solution ? i am having the same problems.
