Hey guys, I am new to HA and have been playing around with it in Docker. I am trying to access it externally through DDNS, but my personal domain name requires SSL. I have tried all of the guides to add my letsencrypt certificate, but home assistant refuses to work.
This is in my configuration.yaml:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
ssl_certificate: /ssl/live/server.mydomain.tld/fullchain.pem
ssl_key: /ssl/live/server.mydomain.tld/privkey.pem
It keeps giving me this error which breaks the whole system:
2023-01-03 00:18:21.827 ERROR (MainThread) [homeassistant.setup] Error during setup of component http
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 360, in _create_ssl_context
context.load_cert_chain(self.ssl_certificate, self.ssl_key)
PermissionError: [Errno 1] Operation not permitted
File "/usr/src/homeassistant/homeassistant/setup.py", line 253, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 185, in async_setup
await server.async_initialize(
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 277, in async_initialize
self.context = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 363, in _create_ssl_context
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Could not use SSL certificate from /ssl/live/server.mydomain.tld/fullchain.pem: [Errno 1] Operation not permitted
I know some users had issues because HA didn’t have access to the full letsencrypt folder path, but I fixed that by adding the following volume mapping to the compose file:
- /private/etc/letsencrypt:/ssl
I confirmed it worked by using the CLI to test if every folder in the /ssl directory was avalible. They all were. Does anyone know what else may be causing this error?
Tinkerer
(aka DubhAd on GitHub)
January 3, 2023, 10:13am
2
GabeMcG:
Personally I’d use a proxy server to handle SSL.
However, if you want to continue this way, I’d open a shell inside the container and see if you can read /ssl/live/server.mydomain.tld/fullchain.pem
docker exec -it homeassistant bash
head /ssl/live/server.mydomain.tld/fullchain.pem
PanMat
(Pankaj)
January 4, 2023, 5:35am
5
What is the output of following command when executed from a client machine?
curl --verbose https://<url>
and the URL is the location of HA machine.
* Rebuilt URL to: https://server.mydomain.tld:8123/
* Trying [ip address]...
* TCP_NODELAY set
* Connected to server.mydomain.tld (ip) port 8123 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
* CAfile: /etc/ssl/cert.pem
CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
* stopped the pause stream!
* Closing connection 0
curl: (35) error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
PanMat
(Pankaj)
January 4, 2023, 6:33am
7
The signed certificate that you have will look something like this:
-----BEGIN CERTIFICATE-----
MIIGsjCCBZqgAwIBAgIQCTaYT9gNC0RFj3x3zaPxZDANBgkqhkiG9w0BAQsFADBw
-----END CERTIFICATE-----
Post the output of following command, you may need to install openssl if it is not already installed:
openssl x509 -in <certificate_file> -text
And redact any sensitive information from the output especially location, address, emails and phone numbers.
PS: From the output you posted “CApath: none” is most likely the source of problem, the certificates is not set up properly as the OS cannot find the CA certificate to authenticate.
Here is the output:
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
[REDACTED]
Signature Algorithm: sha256WithRSAEncryption
Issuer: C = US, O = Let's Encrypt, CN = R3
Validity
Not Before: Dec 31 03:05:23 2022 GMT
Not After : Mar 31 03:05:22 2023 GMT
Subject: CN = server.mydomain.tld
Subject Public Key Info:
Public Key Algorithm: id-ecPublicKey
Public-Key: (256 bit)
pub:
04:20:42:11:6a:8b:b5:87:d1:1e:61:95:f3:33:5f:
d3:90:3c:79:6e:98:54:3c:e7:c7:e8:3f:60:52:f8:
7e:9c:8e:ca:97:0a:fb:06:5a:5b:1a:29:e8:9d:35:
3f:e5:21:f7:5d:0f:bf:b2:49:19:3c:eb:5b:40:a7:
5b:88:71:3b:1e
ASN1 OID: prime256v1
NIST CURVE: P-256
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Basic Constraints: critical
CA:FALSE
X509v3 Subject Key Identifier:
F2:64:5D:57:CA:EF:0E:F5:39:71:40:14:3F:34:FD:E2:DC:D0:AA:E0
X509v3 Authority Key Identifier:
keyid:14:2E:B3:17:B7:58:56:CB:AE:50:09:40:E6:1F:AF:9D:8B:14:C2:C6
Authority Information Access:
OCSP - URI:http://r3.o.lencr.org
CA Issuers - URI:http://r3.i.lencr.org/
X509v3 Subject Alternative Name:
DNS:server.mydomain.tld
X509v3 Certificate Policies:
Policy: 2.23.140.1.2.1
Policy: 1.3.6.1.4.1.44947.1.1.1
CPS: http://cps.letsencrypt.org
CT Precertificate SCTs:
Signed Certificate Timestamp:
Version : v1 (0x0)
Log ID : 7A:32:8C:54:D8:B7:2D:B6:20:EA:38:E0:52:1E:E9:84:
16:70:32:13:85:4D:3B:D2:2B:C1:3A:57:A3:52:EB:52
Timestamp : Dec 31 04:05:23.631 2022 GMT
Extensions: none
Signature : ecdsa-with-SHA256
30:46:02:21:00:96:C3:E7:50:6D:A3:E2:A3:80:68:EC:
97:D6:BD:21:89:69:50:1F:25:C6:CC:87:3B:F4:F4:20:
9B:49:50:30:74:02:21:00:8B:C4:76:44:7C:F4:07:8A:
7F:97:3F:EC:DC:5B:25:8E:B1:5C:FC:70:17:88:38:5F:
E6:82:C7:8B:AF:92:57:FA
Version : v1 (0x0)
Log ID : AD:F7:BE:FA:7C:FF:10:C8:8B:9D:3D:9C:1E:3E:18:6A:
B4:67:29:5D:CF:B1:0C:24:CA:85:86:34:EB:DC:82:8A
Timestamp : Dec 31 04:05:23.755 2022 GMT
Extensions: none
30:45:02:20:1F:C8:45:54:74:F5:98:D9:4D:50:EB:FF:
A2:C8:BA:2B:B6:FB:E5:B1:D7:44:9A:D3:0E:ED:7E:97:
1B:F6:53:FE:02:21:00:D8:63:CF:AD:FF:60:94:A0:F9:
EC:CB:27:39:1B:B2:B9:48:A6:30:E9:41:0C:4B:9E:B6:
69:5F:8D:2D:79:40:A2
6d:f7:05:ba:8b:2f:75:fa:56:f7:2c:39:21:59:73:e6:47:2e:
a8:f5:b0:54:e9:ff:88:43:fc:d1:50:2e:6c:e0:44:b2:1d:48:
34:be:96:a5:c3:74:ef:d1:7c:80:41:d2:c7:af:b1:fc:aa:d8:
e5:d9:88:d9:f4:61:25:5d:c8:aa:19:a0:6e:ed:1b:6b:e9:01:
17:a9:96:68:aa:2c:f3:e8:47:f0:9b:3b:90:6a:78:ee:8e:c4:
b5:91:c8:27:e7:69:81:8d:a2:f5:d0:7b:40:89:26:55:91:44:
db:ea:8e:c3:4f:eb:e9:75:f9:b3:a4:c7:c5:54:7e:6d:82:23:
1b:e7:6b:26:20:2d:87:41:68:22:f7:72:59:ba:48:c3:26:a4:
60:68:02:93:ad:bc:51:28:ad:0e:68:16:17:5e:32:45:34:5c:
eb:0c:2b:53:7f:1c:40:8e:9d:32:ed:91:f4:ab:b4:3b:b5:a9:
cb:db:26:e9:60:07:50:5d:5a:c1:7f:93:7e:6c:16:95:87:e3:
23:74:ac:b4:54:6e:b7:85:62:81:1b:47:91:94:c8:85:45:59:
ef:f0:e5:bc:c5:9c:19:82:45:90:76:c2:57:21:b9:1f:7c:79:
31:e3:63:26:9f:bd:ab:ed:9c:2f:7c:60:25:f1:8b:11:69:c2:
bc:b5:67:62
MIIEaDCCA1CgAwIBAgISAw9pwxW6qNBxDr6YGY+FCBsUMA0GCSqGSIb3DQEBCwUA
PanMat
(Pankaj)
January 5, 2023, 6:07am
9
Great, seems like you listed the correct domain while requesting certificate:
Now check the output of following command from the client machine accessing HA:
ls /etc/ssl/certs/
Do you see Let’s Encrypt in the list of names? If not then it means that Let’s Encrypt CA certificate is not installed on the OS.
That directory is completely empty.
Wait. I think I misunderstood. Did you mean that I should run that command in HA? If so, the HA output is
002c0b4f.0
02265526.0
03179a64.0
062cdee6.0
064e0aa9.0
06dc52d5.0
09789157.0
0a775a30.0
0b1b94ef.0
0b9bc432.0
0bf05006.0
0f5dc4f3.0
0f6fa695.0
1001acf7.0
106f3e4d.0
14bc7599.0
18856ac4.0
1d3472b9.0
1e08bfd1.0
1e09d511.0
244b5494.0
2923b3f9.0
2ae6433e.0
2b349938.0
32888f65.0
349f2832.0
3513523f.0
3bde41ac.0
3e44d2f7.0
3e45d192.0
3fb36b73.0
40193066.0
4042bcee.0
40547a79.0
406c9bb1.0
4304c5e5.0
48bec511.0
4b718d9b.0
4bfab552.0
4f316efb.0
5273a94c.0
5443e9e3.0
54657681.0
57bcb2da.0
5931b5bc.0
5a7722fb.0
5ad8a5d6.0
5cd81ad7.0
5d3033c5.0
5e98733a.0
5f15c80c.0
5f618aec.0
607986c7.0
626dceaf.0
653b494a.0
66445960.0
68dd7389.0
6b99d060.0
6d41d539.0
6fa5da56.0
706f604c.0
749e9e03.0
75d1b2ed.0
76faf6c0.0
7719f463.0
773e07ad.0
7a3adc42.0
7a780d93.0
7aaf71c0.0
7f3d5d1d.0
8160b96c.0
8508e720.0
8cb5ee0f.0
8d86cdd1.0
8d89cda1.0
8f103249.0
90c5a3c8.0
930ac5d2.0
93bc0acc.0
9482e63a.0
9846683b.0
988a38cb.0
9b5697b0.0
9c8dfbd4.0
9d04f354.0
9ef4a08a.0
9f727ac7.0
a3418fda.0
a94d09e5.0
aee5f10d.0
b0e59380.0
b1159c4c.0
b433981b.0
b66938e9.0
b727005e.0
b7a5b843.0
b81b93f0.0
bf53fb88.0
c01eb047.0
c28a8a30.0
ca-cert-ACCVRAIZ1.pem
ca-cert-AC_RAIZ_FNMT-RCM.pem
ca-cert-AC_RAIZ_FNMT-RCM_SERVIDORES_SEGUROS.pem
ca-cert-ANF_Secure_Server_Root_CA.pem
ca-cert-Actalis_Authentication_Root_CA.pem
ca-cert-AffirmTrust_Commercial.pem
ca-cert-AffirmTrust_Networking.pem
ca-cert-AffirmTrust_Premium.pem
ca-cert-AffirmTrust_Premium_ECC.pem
ca-cert-Amazon_Root_CA_1.pem
ca-cert-Amazon_Root_CA_2.pem
ca-cert-Amazon_Root_CA_3.pem
ca-cert-Amazon_Root_CA_4.pem
ca-cert-Atos_TrustedRoot_2011.pem
ca-cert-Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem
ca-cert-Baltimore_CyberTrust_Root.pem
ca-cert-Buypass_Class_2_Root_CA.pem
ca-cert-Buypass_Class_3_Root_CA.pem
ca-cert-CA_Disig_Root_R2.pem
ca-cert-CFCA_EV_ROOT.pem
ca-cert-COMODO_Certification_Authority.pem
ca-cert-COMODO_ECC_Certification_Authority.pem
ca-cert-COMODO_RSA_Certification_Authority.pem
ca-cert-Certainly_Root_E1.pem
ca-cert-Certainly_Root_R1.pem
ca-cert-Certigna.pem
ca-cert-Certigna_Root_CA.pem
ca-cert-Certum_EC-384_CA.pem
ca-cert-Certum_Trusted_Network_CA.pem
ca-cert-Certum_Trusted_Network_CA_2.pem
ca-cert-Certum_Trusted_Root_CA.pem
ca-cert-Comodo_AAA_Services_root.pem
ca-cert-D-TRUST_BR_Root_CA_1_2020.pem
ca-cert-D-TRUST_EV_Root_CA_1_2020.pem
ca-cert-D-TRUST_Root_Class_3_CA_2_2009.pem
ca-cert-D-TRUST_Root_Class_3_CA_2_EV_2009.pem
ca-cert-DigiCert_Assured_ID_Root_CA.pem
ca-cert-DigiCert_Assured_ID_Root_G2.pem
ca-cert-DigiCert_Assured_ID_Root_G3.pem
ca-cert-DigiCert_Global_Root_CA.pem
ca-cert-DigiCert_Global_Root_G2.pem
ca-cert-DigiCert_Global_Root_G3.pem
ca-cert-DigiCert_High_Assurance_EV_Root_CA.pem
ca-cert-DigiCert_TLS_ECC_P384_Root_G5.pem
ca-cert-DigiCert_TLS_RSA4096_Root_G5.pem
ca-cert-DigiCert_Trusted_Root_G4.pem
ca-cert-E-Tugra_Certification_Authority.pem
ca-cert-E-Tugra_Global_Root_CA_ECC_v3.pem
ca-cert-E-Tugra_Global_Root_CA_RSA_v3.pem
ca-cert-EC-ACC.pem
ca-cert-Entrust.net_Premium_2048_Secure_Server_CA.pem
ca-cert-Entrust_Root_Certification_Authority.pem
ca-cert-Entrust_Root_Certification_Authority_-_EC1.pem
ca-cert-Entrust_Root_Certification_Authority_-_G2.pem
ca-cert-Entrust_Root_Certification_Authority_-_G4.pem
ca-cert-GDCA_TrustAUTH_R5_ROOT.pem
ca-cert-GLOBALTRUST_2020.pem
ca-cert-GTS_Root_R1.pem
ca-cert-GTS_Root_R2.pem
ca-cert-GTS_Root_R3.pem
ca-cert-GTS_Root_R4.pem
ca-cert-GlobalSign_ECC_Root_CA_-_R4.pem
ca-cert-GlobalSign_ECC_Root_CA_-_R5.pem
ca-cert-GlobalSign_Root_CA.pem
ca-cert-GlobalSign_Root_CA_-_R3.pem
ca-cert-GlobalSign_Root_CA_-_R6.pem
ca-cert-GlobalSign_Root_E46.pem
ca-cert-GlobalSign_Root_R46.pem
ca-cert-Go_Daddy_Class_2_CA.pem
ca-cert-Go_Daddy_Root_Certificate_Authority_-_G2.pem
ca-cert-HARICA_TLS_ECC_Root_CA_2021.pem
ca-cert-HARICA_TLS_RSA_Root_CA_2021.pem
ca-cert-Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem
ca-cert-Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem
ca-cert-HiPKI_Root_CA_-_G1.pem
ca-cert-Hongkong_Post_Root_CA_1.pem
ca-cert-Hongkong_Post_Root_CA_3.pem
ca-cert-ISRG_Root_X1.pem
ca-cert-ISRG_Root_X2.pem
ca-cert-IdenTrust_Commercial_Root_CA_1.pem
ca-cert-IdenTrust_Public_Sector_Root_CA_1.pem
ca-cert-Izenpe.com.pem
ca-cert-Microsec_e-Szigno_Root_CA_2009.pem
ca-cert-Microsoft_ECC_Root_Certificate_Authority_2017.pem
ca-cert-Microsoft_RSA_Root_Certificate_Authority_2017.pem
ca-cert-NAVER_Global_Root_Certification_Authority.pem
ca-cert-NetLock_Arany_=Class_Gold=_FĹ‘tanĂşsĂtvány.pem
ca-cert-Network_Solutions_Certificate_Authority.pem
ca-cert-OISTE_WISeKey_Global_Root_GB_CA.pem
ca-cert-OISTE_WISeKey_Global_Root_GC_CA.pem
ca-cert-QuoVadis_Root_CA_1_G3.pem
ca-cert-QuoVadis_Root_CA_2.pem
ca-cert-QuoVadis_Root_CA_2_G3.pem
ca-cert-QuoVadis_Root_CA_3.pem
ca-cert-QuoVadis_Root_CA_3_G3.pem
ca-cert-SSL.com_EV_Root_Certification_Authority_ECC.pem
ca-cert-SSL.com_EV_Root_Certification_Authority_RSA_R2.pem
ca-cert-SSL.com_Root_Certification_Authority_ECC.pem
ca-cert-SSL.com_Root_Certification_Authority_RSA.pem
ca-cert-SZAFIR_ROOT_CA2.pem
ca-cert-SecureSign_RootCA11.pem
ca-cert-SecureTrust_CA.pem
ca-cert-Secure_Global_CA.pem
ca-cert-Security_Communication_RootCA2.pem
ca-cert-Security_Communication_Root_CA.pem
ca-cert-Staat_der_Nederlanden_EV_Root_CA.pem
ca-cert-Starfield_Class_2_CA.pem
ca-cert-Starfield_Root_Certificate_Authority_-_G2.pem
ca-cert-Starfield_Services_Root_Certificate_Authority_-_G2.pem
ca-cert-SwissSign_Gold_CA_-_G2.pem
ca-cert-SwissSign_Silver_CA_-_G2.pem
ca-cert-T-TeleSec_GlobalRoot_Class_2.pem
ca-cert-T-TeleSec_GlobalRoot_Class_3.pem
ca-cert-TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.pem
ca-cert-TWCA_Global_Root_CA.pem
ca-cert-TWCA_Root_Certification_Authority.pem
ca-cert-TeliaSonera_Root_CA_v1.pem
ca-cert-Telia_Root_CA_v2.pem
ca-cert-TrustCor_ECA-1.pem
ca-cert-TrustCor_RootCert_CA-1.pem
ca-cert-TrustCor_RootCert_CA-2.pem
ca-cert-Trustwave_Global_Certification_Authority.pem
ca-cert-Trustwave_Global_ECC_P256_Certification_Authority.pem
ca-cert-Trustwave_Global_ECC_P384_Certification_Authority.pem
ca-cert-TunTrust_Root_CA.pem
ca-cert-UCA_Extended_Validation_Root.pem
ca-cert-UCA_Global_G2_Root.pem
ca-cert-USERTrust_ECC_Certification_Authority.pem
ca-cert-USERTrust_RSA_Certification_Authority.pem
ca-cert-XRamp_Global_CA_Root.pem
ca-cert-certSIGN_ROOT_CA.pem
ca-cert-certSIGN_Root_CA_G2.pem
ca-cert-e-Szigno_Root_CA_2017.pem
ca-cert-ePKI_Root_Certification_Authority.pem
ca-cert-emSign_ECC_Root_CA_-_C3.pem
ca-cert-emSign_ECC_Root_CA_-_G3.pem
ca-cert-emSign_Root_CA_-_C1.pem
ca-cert-emSign_Root_CA_-_G1.pem
ca-cert-vTrus_ECC_Root_CA.pem
ca-cert-vTrus_Root_CA.pem
ca-certificates.crt
ca6e4ad9.0
cbf06781.0
cc450945.0
cd58d51e.0
cd8c0d63.0
ce5e74ef.0
d4dae3dd.0
d52c538d.0
d6325660.0
d7e8dc79.0
d887a5bb.0
dc4d6a89.0
dd8e9d41.0
de6d66f3.0
e113c810.0
e18bfb83.0
e35234b1.0
e36a6752.0
e73d606e.0
e868b802.0
e8de2f56.0
ecccd8db.0
ed858448.0
ee64a828.0
eed8c118.0
ef954a4e.0
f081611a.0
f0c70a8d.0
f249de83.0
f30dd6ad.0
f3377b1b.0
f387163d.0
f39fc864.0
f51bb24c.0
fa5da96b.0
fc5a8f99.0
fd64f3fc.0
fe8a2cd8.0
feffd413.0
ff34af3f.0
PanMat
(Pankaj)
January 5, 2023, 8:03am
12
Not from HA machine but from the machine where you are trying to access server.mydomain.tld.
If you see blank directory or Let’s Encrypt missing then run this command:
update-ca-certificates
And check the output of:
ls /etc/ssl/certs/
That command was not found. Also, the issue is not with accessing HA. It is with starting HA. HA is failing to start http because it cannot read the SSL cert for some reason. See my initial post:
GabeMcG:
result = await task
PanMat
(Pankaj)
January 5, 2023, 6:03pm
14
Try moving “fullchain.pem” and “privkey.pem” to /ssl folder and then try a simpler configuration like below to see if you still get the error:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Actually, I think the error has magically disappeared. I have zero clue what I did differently, but it is gone. I do have to use the complex path configuration though because fullchain.pem and privkey.pem are aliases for files in a different folder that docker says it does not have access to. This is just how LetsEncrypt does things.
Now the issue is all of my computers (Windows, Mac, and iOS) all say ERR_SSL_PROTOCOL_ERROR
when I try to use https to access the site.
Wait. Nope. I lied. Docker was using the wrong config file and was not looking at the one where I had my SSL files listed. We’re right back to getting the original error.
Tinkerer
January 5, 2023, 9:24pm
17
What if you point it directly to the actual files?
It appears to start without any errors, but it still does not let me access it with https.
Tinkerer
January 8, 2023, 9:40pm
19
It’s either going to start without errors with HTTPS, or no HTTPS and errors… or you’ve not actually configured it correctly.
You’re right. Silly mistake. Modified the config in nano instead of my normal VS code and forgot to remove the comments because I didn’t have the colors to remind me. It still says that operation is not permitted.
Tinkerer
January 9, 2023, 7:35am
21
That error is likely permissions. The user running HA in the container can’t read the file(s).
