I have been setting up Let’s encrypt as per instructions here home-assistant.io/blog/2015/12/ … s-encrypt/
However there seems to be a permission issue.
Feb 12 20:43:50 deepi hass[2596]: ERROR:homeassistant.components.http:Error setting up HTTP server
Feb 12 20:43:50 deepi hass[2596]: Traceback (most recent call last):
Feb 12 20:43:50 deepi hass[2596]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/http.py", line 69, in setup
Feb 12 20:43:50 deepi hass[2596]: development, ssl_certificate, ssl_key)
Feb 12 20:43:50 deepi hass[2596]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/http.py", line 117, in __init__
Feb 12 20:43:50 deepi hass[2596]: context.load_cert_chain(ssl_certificate, keyfile=ssl_key)
Feb 12 20:43:50 deepi hass[2596]: PermissionError: [Errno 13] Permission denied
Feb 12 20:43:50 deepi hass[2596]: ERROR:homeassistant.bootstrap:component http failed to initialize
Feb 12 20:43:50 deepi hass[2596]: ERROR:homeassistant.bootstrap:Not initializing api because not all dependencies loaded: http
Any ideas? Do I need to run HA as root? Many thanks.
