Let's start talking about the new Z-wave JS integration
Yeah I couldn’t get my entities to come back so I’m playing the rename game. Also my Honeywell Thermostat lost its climate entity today so as of right now my automations can’t adjust the temp in the house. Trying to get them to show back up via re-interview does not work. It does look like the fan portion of the device was enabled in the release though so thats good will be good when I can add it back to HA
Thanks for guiding me, anyway I had to reset my zw network and add all sensors from scratch.
None of other solutions worked for me
Luckily I only have 8 sensors at the moment
better than my 70+
HI Guys
I have some Devolo thermostats. Hvac_mode doesn’t work anymore, since you switched to ZWave JS. Is anyone aware of this?
Hi
My fibaro roller shutter v3 dort work with zwave js. I see the shutter on my devices but i cannot control them
Yeah same thing happens with my honeywell thermostat since the update to dev yesterday
Right there with ya. Thankfully 99% of my network is working great! Just need my GoControl garage door cover support and then I am set.
I’m just waiting on the Yale lock support to notify of manual control. I see a note on node-zwave-js v6.3.0 release notes “improve Yale Lock support” so I’m hopeful. Just waiting on the next release of zwavejs2mqtt to implement that since it’s a commit already.
This is great. So just to make sure I understand, Does that mean if I find something on this list, that it should work with HA and Z-WaveJS. I see my garage door opener on the list, but the cover does not show up. Again, not pushing at all, I’m not in a rush, I just want to understand what “supported” means.
I finally got most of my battery devices working by Re-Interviewing each node. Perhaps they would have been discovered eventually by just waking them up as suggested…but after a day I decided to try Re-Interviewing them, and for the most part it seemed to work. I’m running ZwaveJS-to-MQTT. I am having an issue with one of my ZW089 Recessed Door sensors. The entities are showing in the the ZwaveJS management screen, but most are showing as disabled in HA. I have Re-Interviewed and even removed and Included this again…but so far no luck getting it to show in HA. I can see in the logs it is working.
I have the monoprice recessed door sensors (ZD2105). One of my 3 was a pain and wasn’t showing the binary sensor entity at all. One night I pulled it out of the wall and sat on the couch. I kept waking it up and clicking re-interview. I think a restart of zwavejs2mqtt and hass also. Finally got all the entities in there and working.
I would love to know the answer to this as well. I have 2 usb sticks, one in each floor and hoping someone has done some testing to see if having one big mesh over 2 floors is better than 2 different meshes over single floors.
You are not alone in this boat
No, it’s not that simple. Having the config should mean it is recognized, and commands the ZwaveJS driver and HA can handle will work, the “but” here is whether the device uses commands not supported by ZWaveJS or HA yet. To determine that what I have done so far is scour the equipment manuals to see the commands it needs, the supported commands list (on ZWaveJS github), the HA release notes, and the respective forums/issues lists for others trying to use that device.
I understand if it’s not supported…but these (ZW089 Recessed Door sensors) are on the list of supported devices. And I have 3 other ZW089 Recessed Door sensors that are working correctly…or at least passing some entity thru to HA that shows when the door is open/closed. It took a lot of work (Re-Interviewing / Remove and Include again, etc) with the others to eventually get them working, but one is still having issues.
Old zwave integration had a setting called “refresh_value”.
Is there an equivalent for zwavejs integration?
My hs-wd200’s won’t keep sync in HA with the actual light state.
Had to change my docker label from dev to latest due to the thermostat no longer showing up in HA. The only thing that was reporting in was the temperature. On later versions the climate device for some weird reason stops coming in.
IIRC, there is a fix slated for the next HA release/beta for this.
well check with me in 2 months. i am trying to create a mesh over 5 floors!
wish me luck!
I have some Heatit floor thermostats version 2 (TF016 is the zwavejs product code).
At first, they appeared with a thermostat and a temperature, fine.
Then, after a while, the thermostat became unavailable in the HA integration.
I excluded and re-included them.
Now they don’t show the thermostat at all! Only the temperature.
In zwavejs2mqtt they look fine.
What’s wrong?
